Erratic Engine Oil Consumption
4 replies to this topic
#1 Missminimouse
Missminimouse
    Starting My Mini Up
  • 2 posts
Posted 04 September 2016 - 12:35 PM
I've owned my 57/08 cooper s JCW for nearly 3 months and can't get to grips with the oil use.
It's done 62k miles, only 2000 of which by me and I've already gone through around 4 litres of oil! Is this normal? I was told it could use around 1 litre to every 1000 miles - but the same person who told me this told me to dip and check the oil with the engine HOT!?! I don't - I always check it cold in a level surface.
I'm using 5w30 fully synthetic. Topped it up to th maximum level - 360 miles later it's just above the minimum! I've never once seen a spot of oil on the ground after moving it so it's not got a leak!
#2 dyshipfakta
dyshipfakta
  • 1,696 posts
Posted 04 September 2016 - 01:19 PM
Wrong forum pal this is old minis that do burn oil pretty regularly. If it's a JCW could well be burning oil usually turbo oil seals with that kind of consumption. It's not normal
#3 mab01uk
mab01uk
  • 12,494 posts
Posted 04 September 2016 - 01:30 PM
Some classic Mini owners on here do also own Modern MINI's but you will probably get more responses on the TotalMINI forum link below:-
http://www.totalmini.com/forum/
#4 Missminimouse
Missminimouse
    Starting My Mini Up
  • 2 posts
Posted 04 September 2016 - 02:38 PM
Aw balls! My brother (another JCW owner!) just said "join TMF" Okay thanks guys!
#5 jamesmpi
jamesmpi
  • 1,940 posts
Posted 04 September 2016 - 03:50 PM
There are quite a few people on here who own MINIs but you'll probably find an answer quicker on a dedicated MINI forum
