I have a horrible rattling coming from my single row timing chain and I am trying to decide if the engine is worth having the timing chain work done now or if I should anticipate a full rebuild soon. The labor quote for replacing the timing chain is $1,000 to $1,200 USD so I hate to waste money doing it now if I am going to need a full rebuild soon.
The engine starts and runs well and doesn't smoke much, although there is a little soot/residue that builds up on my rear bumper over time. It has a lot of power but sounds like a diesel due to the timing chain rattle.
I did a compression check - the #1 and #4 cylinders were at 160 psi while #2 and #3 tested at 140 psi warm so about 15% variance. This is a Metro low compression engine by the way.
When I start my engine the oil pressure gauge is pegged at 95 to 100 at idle, revs, and driving. After about five minutes warm up the pressure gets down to about 60 at idle, 70 to 75 cruising and 90 +/- when accelerating hard. Once fully warm the idle is 15 to 18, normal driving and cruising is around 45 to 50, and hard acceleration is 75 +/-. Is this normal?
What else should I check out before committing to having the chain done? Any advice would be appreciated.
