Welders 15 Amp
12 replies to this topic
#1 Minimattvan
Minimattvan
  • 105 posts
Posted 20 September 2016 - 07:18 PM
Hi, lots of people reccomend the Clark 151 te welder.
I think this runs off a 15 amp plug instead of a standard 13 amp. Does this plug work in a normal 240 v socket ?
Thanks, would appreciate some help!
#2 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,080 posts
  • Name: Neil
Posted 20 September 2016 - 07:24 PM
im surprised it says in the blurb it should be hard wired to be honest. Fit a 16amp blue plug with a stand alone power supply should be more than adequate.
#3 dyshipfakta
dyshipfakta
  • 1,696 posts
Posted 20 September 2016 - 07:51 PM
The 135 is perfectly adequate for mini stuff. Haven't had any issues at all and runs off the mains it of the box. Cheaper too
#4 Ethel
  • 26,074 posts
Posted 20 September 2016 - 08:14 PM
The advantage over 13 amp is no fuse to blow. You'd want a dedicated 16 amp supply with RCD though.
#5 Minimattvan
Minimattvan
  • 105 posts
Posted 21 September 2016 - 10:31 PM
Yeh, I wasn't expecting it to need a 15 amp plug- they don't seem to be used anywhere- at least I've never seen one until I googled it. The blue plugs are a lot more common so might order one of those for it. Weird that they sell you the welder but don't include a plug with it! Just leave a length of cable sticking out!
What is RCD ?
Does anyone else have the 151 te welder ? What plugs do you have on it ?
#6 sonikk4
sonikk4
  • 16,080 posts
  • Name: Neil
Posted 22 September 2016 - 12:27 AM
Residual current device.
In my workshop I have 2 stand alone circuits. One is for the compressor and the other is for a welder/spot welder. The one I have at home is fitted with a MCB due to the start up loads generated by my other compressor. Both the workshop circuits will have these installed very soon.
So basically this is what you will need to be safe otherwise all you will keep doing is blowing fuses or tripping a ring main CB.
#7 djdanmk
djdanmk
  • 81 posts
Posted 22 September 2016 - 09:43 AM
A blue single phase 16A commando socket and plug is what you need. Depending on the age of your house your consumer unit may already have an rcd fitted or if your garage has its own consumer unit fitted this may have one.
It is best to wire a dedicated circuit in 4mm or 6mm cable for something like this but it all depends on length of runs.
If in dought get an electrician to have a look for you.
Rcds in consumer units look like this
http://www.screwfix....ma-dp-rcd/57083
#8 GraemeC
GraemeC
  • 7,440 posts
Posted 22 September 2016 - 09:56 AM
I really wouldn't go down the 15A route - they are a weird beast, not used much and really not for this purpose.
As above, a blue single phase 16A IEC60309 commando socket and plug is what you need, with suitable gauge wiring
#9 hazpalmer14
hazpalmer14
  • 685 posts
  • Local Club: cumbria mini cruisers
Posted 22 September 2016 - 10:49 AM
I've got a snap on welder i'll be selling shortly if you're after one?
#10 benm
benm
  • 111 posts
Posted 22 September 2016 - 06:27 PM
I have a clarke 160EN turbo its 150amp and im runing it of a standard 13a plug, used it many times on full power and haven't had any problems
#11 sonikk4
sonikk4
  • 16,080 posts
  • Name: Neil
Posted 22 September 2016 - 07:56 PM
Just to add to this thread, I bought a 100 Ltr 3 Hp Clarke compressor about six years ago.
Now that did not come with a 3 pin plug fitted and the technical details said it would be fine running a 13 amp socket. So got it home, plugged it in and boom fuse blew. Mmm thought it may have been an old one so changed it tried the compressor and it popped again.
Righto rang their tech services and they catagorically stated it should run on a 16amp socket as per the technical instructions. I did point out the error of their statement with an emailed copy of the instructions I had quite clearly stating a 13 amp 3 pin plug was fine.
No reply to that as it happened. When the compressor developed a fault and took it back to Machinemart even the manger said the instructions said it was a 16amp plug required. Showed him my instruction manual and pulled one off the shop floor for the same model, all said 13amp 3 pin. He accepted someone somewhere has failed. Bit late to admit that as it goes.
So a ******* up by Clarke. However when I fitted a 16amp RCD that kept blowing as well. It turned out that the compressor has a high start up load so a 32 amp MCB is needed.
Do check the instructions thoroughly.
#12 Batmini
Batmini
  • 378 posts
Posted 23 September 2016 - 06:19 AM
What is RCD ?
I'm really surprised in this time of heightened health and safety and the free 'where there's a blame there's a claim' they still get away with this. I think they don't put a plug on it so that most people don't realise they're not really designed for domestic power. No one, as standard has a 16 amp socket in their shed or garage so they leave it off knowing that many will put a 'standard 13 amp' 3 pin plug on it. Absolving them of any blame should an accident happen
#13 Ethel
  • 26,074 posts
Posted 23 September 2016 - 09:56 AM
Though, to be fair, the most likely outcome is a lot of blown fuses. The welder isn't the risk, it's the circuit you attach it to.
