Rover Wire Diagram Single Insrument Pack 1984-On
electrical
3 replies to this topic
#1 Mike L
Mike L
  • 159 posts
Posted 21 September 2016 - 03:18 PM
I copied another wire diagram from the Rover manual. I redrew it  and spread the components out so hopefully it is easier to follow. I have noticed that when the PDF is opened online some of the things I added using Foxit PDF reader/editor are not visible until I down load it and open it in any regular PDF reader. it's in a big format so you can't read much in full page view but when you zoom in on things it's very readable. Let me know if you find any errors so I can fix them.
Edit: added missing starter ground symbol
Edit 2: corrected miss labeled direction indicator warning lamp
Edit 3: corrected mislabeled rear screen switch
Edit 4: put the color codes & title back on (lost them in Edit 3)
Edit 5: added missing N wire between light switch and fuse 3-4
[attachment=185331:ROVER WIRING DIAGRAM SINGLE INSTRUMENT PACK 1984-ON PAGE 86-34.PDF]
Edited by Mike L, 27 September 2016 - 01:32 PM.
#2 Magneto
Magneto
  • 889 posts
  • Local Club: KC MINI Club
Posted 21 September 2016 - 03:50 PM
You need to add a legend - that identifies the different components......also, is there a fog light in the diagram?
Instruments has a "T" in it, just FYI... :-)
Thanks for doing this!
Edited by Magneto, 21 September 2016 - 03:50 PM.
#3 Mike L
Mike L
  • 159 posts
Posted 21 September 2016 - 04:21 PM
Zoom in on the components. The names are on them. In the Rover manual the front fog lights are not on this diagram. It took me a bit to figure out the "T" you were talking about was in the file name and not on the drawing.
Edited by Mike L, 21 September 2016 - 04:28 PM.
#4 Magneto
Magneto
  • 889 posts
Posted 21 September 2016 - 05:39 PM
OK, cool....I'll try that. I was talking about the rear fog light, not fronts.....maybe if I zoom in it's there and I just didn't see it?
Edit - found the fog light switch!
I think I'll have Kinko's blow me up a copy so I can read it without scrolling back and forth.
Edited by Magneto, 21 September 2016 - 05:41 PM.
