Best Drill Bit Size For Plug Welding
Best Answer minidaves , 26 September 2016 - 06:32 AM
6 or 8 mm depends
Go to the full post
9 replies to this topic
#1 GT Jimmy
GT Jimmy
  • 1,644 posts
  • Local Club: S.U.N.M.C
Posted 25 September 2016 - 08:34 AM
Probably been asked on here many a time but what's the best size bit for plug weld holes? Was thinking 6 or 7mm. Thanks
#2 Marco1972
Marco1972
  • 822 posts
Posted 25 September 2016 - 08:52 AM
I use 6 MM on 99% of my plug welds
5mm occasionally
Edited by Marco1972, 25 September 2016 - 08:52 AM.
#3 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,025 posts
Posted 25 September 2016 - 08:57 AM
6MM for me to
#4 GT Jimmy
GT Jimmy
  • 1,644 posts
Posted 25 September 2016 - 09:02 AM
Thanks. Off to screwfix now
#5 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 25 September 2016 - 10:54 AM
Go 8mm in more structural areas although i expect you will read this after you return from Screwfix  >_<
#6 GT Jimmy
GT Jimmy
  • 1,644 posts
Posted 25 September 2016 - 11:44 AM
Indeed I did haha
#7 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,037 posts
  • Name: Neil
Posted 25 September 2016 - 03:24 PM
1/4" is perfect for most heavy duty applications. BUT remember the size of the flange will dictate what size drill bit to use.
The smallest I will go down to is 3/16ths. 5/32nd is too small. The hole will fill first without making a decent puddle of weld to the underlying panel rendering it weak.
8mm Ben is a monster but I can see its application in a couple of areas.
#8 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 25 September 2016 - 03:42 PM
A majority of plug welds i would do using a 6mm hole but i do like to go a bit overkill in some areas like heel and toe boards. the other option using 6mm holes is to space them quite closely to give more strength.
#9 GT Jimmy
GT Jimmy
  • 1,644 posts
Posted 25 September 2016 - 09:40 PM
On the front toe boards I drilled the spot welds out using an 8mm spot weld drill, just thought it would get the welds easier. Guess I just got lucky haha
#10 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 26 September 2016 - 06:32 AM   Best Answer
6 or 8 mm depends
