Easy Way To Depressurise Hydrolastic?
15 replies to this topic
#1 msgorbra
msgorbra
  • 19 posts
Posted 27 September 2016 - 06:11 AM
Hi,
I'm about to switch from hydrolastic to rubber suspension and want to know how to depressurise when I don´t have access to a real pump.
regards Goran
#2 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 27 September 2016 - 06:49 AM
jack car in air all 4 wheels off the ground to take the pressure out the system then wear eye/full face protection and gently crack the pipe nuts, slowly lower car back on wheels and the fluid will come out. job done
#3 msgorbra
msgorbra
  • 19 posts
Posted 27 September 2016 - 07:23 AM
Thanks a lot, when you say "crack the pipe nuts", I suppose you mean the first smaller nut after the valve?
#4 Spider
  • 15,059 posts
Posted 27 September 2016 - 08:05 AM
I just leave them on the ground, then using a Schrader Valve Tool (or even some valve caps have them on the other end), crack the valves about 1/2 to 1 turn until the fluid stops flowing, then remove the valves altogether.
It will stink and it will make a bit of a mess but nothing that won't hose away.
#5 nicklouse
  • 18,662 posts
Posted 27 September 2016 - 08:10 AM
how about this.
get a suitable cycle pump flex hose. you remember it screws into the old style pump and then onto the valve.
at least that would give you a means of directing the fluid into a container.
not tried it yet but it could be a plan.
#6 msgorbra
msgorbra
  • 19 posts
Posted 27 September 2016 - 10:27 AM
Thanks for replies! The car stands without hubs so it´s in the air.
#7 CobraV8
CobraV8
  • 991 posts
Posted 28 September 2016 - 09:45 AM
I watched a guy do this once, on the front of the rear subframe poked a screwdriver into valves and let it all out.
#8 Ethel
  • 26,033 posts
Posted 28 September 2016 - 10:42 AM
Wear goggles and waterproofs, or use a very long scrfewdriver (like 6ft) if you go for that option!
#9 mini13
mini13
  • 3,811 posts
Posted 28 September 2016 - 11:06 AM
Ive let it out on metro's loads of times with just a screwdriver, i'm not saying its a good idea though.
however, once the fluid comes out its not at pressure, much like when pressure vesels are pressure checked, they use a liquid as its incompressible so if the vesel splits the presure is gone and there is no explosion. that said you do have a spring in there on the hydrolastic....
another analogy, bleeding brakes, most people are happy to crack a bleed nipple with somone pressing on the peddle, the pressure behind it is similar, possibly ore in a braking system
#10 Ethel
  • 26,033 posts
Posted 28 September 2016 - 11:15 AM
I'm not saying it's particularly dangerous, just very messy. Sticking your thumb on a running tap makes a better analogy. I learned that lesson the hard way!
#11 mini13
mini13
  • 3,811 posts
Posted 28 September 2016 - 02:03 PM
not as bad as a metro thats been filled with Citroen LHM fluid! LOL  that was apopular mod back in the day to increase damping by the way
#12 Magneto
Magneto
  • 889 posts
  • Local Club: KC MINI Club
Posted 28 September 2016 - 02:44 PM
Really? That green fluid was/is expensive!
#13 mini13
mini13
  • 3,811 posts
Posted 28 September 2016 - 06:35 PM
Yep, Motobuild used to do it as a service at one point for the K series metro's.
#14 Ethel
  • 26,033 posts
Posted 28 September 2016 - 11:04 PM
Hydrolastic fluid is reputedly just water with a rust inhibitor/antifreeze in it.
#15 Magneto
Magneto
  • 889 posts
Posted 29 September 2016 - 12:12 AM
Yep, I heard it was just a glycol/water mix......
