Hi,
I'm struggling to remove a seized bolt on the ball joint end of the tie bar, the nut end snapped off, after trying with it in place I also ended up cutting the bolt head off to try and relieve tension.
I've tried all I can with the access I have so my last option is to drill it out. I've never drilled into stainless steel before and quickly found out my HSS bits weren't going to cut it so I bought some cobalt bits and some cutting fluid, I was suprised it barely made a scratch but figured the issue must be my drill, it's a cheapy, a 12V cordless Black n Decker costing £40 about 3 years ago, I tried various speeds, taking my time, I used a centre punch also.
Is it my crappy drill? If so can someone advise me on a adequate replacement please, I'm a total newb and the options are baffling me, I don't have a lot to spend as I've got new tools coming out my rear, the mrs will kill me soon. I was looking at these two:
http://www.screwfix....-2-li-plus-1...
http://www.screwfix....3rfw-18v-3-0...
Thanks for any help.
