Duplex Timing Cover
Posted 29 September 2016 - 05:33 PM
Posted 29 September 2016 - 07:23 PM
DSN/Retrosport make one that's compatible with both simplex and duplex.
Posted 29 September 2016 - 08:24 PM
BMC and Leyland did.
Find a pre-1976 Timing Chain Cover, problem solved.
Posted 29 September 2016 - 08:40 PM
And front plate.BMC and Leyland did.
Way easier to mod what you have and it ain't hard to do.
Posted 29 September 2016 - 08:59 PM
Isn't it literally just hammering the dimple out so its flat?
Posted 29 September 2016 - 09:01 PM
I'm pretty sure you don't need the front plate, but yes, I agree that to mod a later one is easy enough.
It's what I do.
Posted 29 September 2016 - 09:02 PM
Yeap, but also taking some care so as to not distort the gasket face nor the seal location, though I think you'd be going hard to damage these.
Posted 29 September 2016 - 09:04 PM
I thought the tensioner bump meant there was a hole in the wrong place?And front plate.BMC and Leyland did.
It's what I do.
I always thought you needed to use matched A or A+ front plates.
Posted 29 September 2016 - 09:29 PM
It's what I do.
Nah. I need to modify the Pre-tensioner types to use them with a Tensioner (drill one hole), but not the other way around.
Also, with the 'dimple' that needs bashing out, not all tensioner type cover have that dimple, so can go straight on.
Posted 30 September 2016 - 11:06 AM
Do you know if anyone still supplies those new (original or remanufactured)?
And if not, any advice on how to identify them?
Posted 30 September 2016 - 11:09 AM
they are the old A series ones. not '"new".
Posted 30 September 2016 - 04:39 PM
It took me all of 2 minutes to do.
Posted 30 September 2016 - 08:53 PM
I doubt you'd find a new one, but I'm sure they come up on ebay often enough. They look like this;-
another option, as I mentioned before, is that there are some late timing chain covers that just fit right on, no modifications needed at all,
eg;-
https://minispares.c...|Back to search
