m.o. failures...
Posted 10 September 2006 - 01:18 AM
1: Offside front suspension has inadequate clearence with the bump stop.
- Can this be easily remedied as I have front hi-lo's?
2: (Rear silencer FRONT mounting) exhaust system mounting missing.
- Is this an easy fix? And what part should I be looking to purchase?
3: Nearside track rod end ball joint has excessive play.
- Easy to replace? What do i need to purchase?
4: Offside front upper (swivel ball joint) suspension arm has excessive play in a ball joint.
- Again... easy to replace? What do i need to purchase?
Any help would be great. If i could get help on all the topics mentioned that would be frickin excellent!
Thanks again guys!
Jason
Posted 10 September 2006 - 03:02 AM
2: think this must be the mounting on the front of the rear subframe which is this or something similar... check to see what part is missing before ordering. Mounting
3: track rod ends are about a fiver and easy to replace TrackRodEnd just remember to break the locknut first... i spent ages scratching my head because i for got to... when you've done that it just screws off and new one screws on (To the same position!)
4: couldn't find a link for this one but it shouldn't be too hard to find... i've never replaced one myself so i'll leave someone else to explain or maybe search the forum im sure someone will have asked how to replace this before.
Oh and im not really up at 4am replying to posts... im in the states for a week.
Edited by Don't Panic, 10 September 2006 - 03:04 AM.
Posted 10 September 2006 - 07:30 AM
no 4. is a ball joint that needs either replacing or you might get away with re-shimming. up to you. personally i would get a whole new ball joint on there. can be a very annoying job to do!!
Posted 10 September 2006 - 07:59 AM
although even when you know what to do it still a very annoying job. (i think i just hate it more because ive done it so many times lol)
you will need a ball joint splitter either the wedge type or the scissor type.
oh and its handy to have a huge socket to fit over the dome nut too. cant remember the exact size but it will make your life 100x easier.
follow the haynes maunel word for word and its only a couple of hours job. (if youve never done it before).
lol good luck mate!
Posted 10 September 2006 - 08:08 AM
Posted 10 September 2006 - 10:43 AM
Posted 10 September 2006 - 12:55 PM
Posted 10 September 2006 - 02:09 PM
Posted 10 September 2006 - 02:42 PM
1 5/16" is hub nut (disks) plus a few other bits.
Matt
Posted 10 September 2006 - 04:33 PM
Retro 10's said 1/2"
Posted 10 September 2006 - 05:28 PM
sorry. anyway the main thing is, I'm right lol
Posted 10 September 2006 - 05:56 PM
as for the ball joints, its easy to pop them in to a garage (if u take the hubs off), they normally undo them free.
Posted 10 September 2006 - 10:11 PM
be carefull buying track rod ends as some are longer than others. the longer ones are for lowered cars.
Yeah I saw on the minispares website that there are longer ones. I have front hi-los which I think i have to raise. Would the longer track end rods benefit the mini in any way?
Posted 11 September 2006 - 08:08 AM
