Why Would You Do This To A 12G295 Head?
16 replies to this topic
#1 joet999
joet999
  • 119 posts
  • Local Club: medway mini club
Posted 01 October 2016 - 10:00 AM
Is there any reason why you would cut this in to the head? See attached photo.
#2 nicklouse
  • 18,998 posts
Posted 01 October 2016 - 10:07 AM
To redirect the oil way to the stud hole. There will be another grove on the other side.
Is required when you need to skim the head a lot to get a suitable compression relation.
All covered in Vizards book.
#3 joet999
joet999
  • 119 posts
Posted 01 October 2016 - 10:12 AM
Cheers,  I've got a copy of that but I haven't got round to studying it all yet. It will hopefully be going on my A+ 998 so looks like it may have already been skimmed down for it.
#4 Turbo Phil
Turbo Phil
  • 2,427 posts
Posted 01 October 2016 - 10:21 AM
As above. It's probably had a huge skim. Measure the chamber volume to see if it's suitable for your application.
Phil.
#5 nicklouse
  • 18,998 posts
Posted 01 October 2016 - 10:30 AM
And to be honest it looks like it needs another big skim.
Maybe why it is in such poor condition as it was deemed scrap.
#6 sledgehammer
sledgehammer
  • 3,129 posts
Posted 01 October 2016 - 10:32 AM
wonder how much oil seeps out the HG when this is done
& yes looks like it will need a fair bit of love , to make good again
#7 joet999
joet999
  • 119 posts
Posted 01 October 2016 - 10:34 AM
I've not got my hands on it yet. It needs a fair skim for a 87' 998cc I think. I can fix an engine bit I'm no pro. unbolting things fixing and putting it back together is where I'm at. when it comes to compression rations and all that jazz I will have to ask or do some serious reading.
#8 nicklouse
  • 18,998 posts
Posted 01 October 2016 - 11:13 AM
I've not got my hands on it yet..
I would give it a miss.
#9 dyshipfakta
dyshipfakta
  • 1,696 posts
Posted 01 October 2016 - 01:07 PM
Looks like a big paperweight to me.
#10 Spider
  • 15,684 posts
Posted 01 October 2016 - 07:41 PM
As long as it's not cracked, it would be OK. Needs a clean up, but I've had much worse and they can come up like new. I wouldn't be at all worried about the way they have redone the Oil Feed, but I would want to see what the Combustion Chamber Volume is before buying.
#11 joet999
joet999
  • 119 posts
Posted 02 October 2016 - 07:33 AM
Is there any way to increase the combustion chamber size if it is too small? My dad said that they used to re-size the kidney shape to improve performance back in the 70's but he couldn't remember if it was this head or just a standard 998 head. ill let him off as it was a while ago. can you get such a thing as a thicker gasket?
Its only costing me £60 as its a bit of an unknown entity, but I though it was worth a punt at that price. If it is no good ill have to make some mini memorabilia out of it.
#12 Broomer
Broomer
  • 1,771 posts
Posted 02 October 2016 - 07:37 AM
It could be useful to hold the edges of tarporline down or to wedge doors open on windy days.
#13 Spider
  • 15,684 posts
Posted 02 October 2016 - 08:15 AM
If you're in to small bore engines, it would easily be worth 60 quid.
If the cambers are found too small in volume, you can open them up with some careful work with a die grinder, or you can find some higher volume dished pistons. Until you get a hold of it, and CC it, you won't really know. One of the 'problems' with these heads is that they had a big chamber to start with and many factory engines that they were fitted to had a raised section on the piston to compensate for this.
#14 Turbo Phil
Turbo Phil
  • 2,427 posts
Posted 02 October 2016 - 08:30 AM
You can open the chambers a bit. Here's the last one I did. It had been skimmed to give 25cc. I managed to restore the original chamber size.
Phil.
#15 Spider
  • 15,684 posts
Posted 02 October 2016 - 08:45 AM
Nice work Phil! :shades:
