Heater Pipes 1000 - 1275
6 replies to this topic
#1 yellowminipower
yellowminipower
    Just On Tickover
  • 5 posts
Posted 02 October 2016 - 08:31 AM
I have recently bought a 1000 mini and put in a 1275 a plus engine in. Does the heater pipes work in the same way or do they need to be plumbed in different as I don't have any heat.
I really want to know where to start to fix this as winter is coming and want to use mini
Thanks in advance
#2 nicklouse
  • 18,998 posts
Posted 02 October 2016 - 08:37 AM
There is no difference.
You may have an air lock or a poor water pump.
#3 yellowminipower
yellowminipower
    Just On Tickover
  • 5 posts
Posted 02 October 2016 - 08:40 AM
Thanks sorry to be a noob but got to check
#4 sledgehammer
sledgehammer
  • 3,129 posts
Posted 02 October 2016 - 09:53 AM
as above -
It's a valid question for anyone to ask , noob or not
if in doubt , ask - there is always someone who will know on here
another possibility is a matrix has got blocked with crud from the 1275 engine ,
there is usually crud sat at the bottom of the water jackets , when this dries out , it sometimes flakes off & finds a new home in the heater matrix
but my money on air lock first , pump the larger hoses - see if air comes out
best of luck
(remember antifreeze this time of year - easily forgotten)
#5 tiger99
tiger99
  • 8,584 posts
Posted 02 October 2016 - 02:19 PM
Can you post a picture or two of how you have the pipework arranged? It may help a diagnosis.
It could be as simple as an airlock at a high point. But disconnecting both hoses and flushing the heater through in both directions with a garden hose is a useful thing to do anyway as, as already suggested, they do get bunged up with crud.
#6 yellowminipower
yellowminipower
    Just On Tickover
  • 5 posts
Posted 02 October 2016 - 04:17 PM
as above -
best of luck
#7 yellowminipower
yellowminipower
    Just On Tickover
  • 5 posts
Posted 02 October 2016 - 05:17 PM
I've got to clean the system out, as mentioned it is dirty. I will clean matrix out and I'm putting a new radiator on anyway so hopefully this will sort it out
Thanks for your help
