Rear Adjustable Camber/toe Brackets
Posted 08 October 2016 - 10:05 AM
Just been looking at various brackets on offer - Minispares, Mini Sport & KAD.
Minispares are £46ish
Mini Sport are £54ish
KAD are £130ish
Are there any alternatives?
I always look for good quality items that are going to last, but are the KAD items really worth paying £130?
Posted 08 October 2016 - 10:53 AM
https://www.minispar...69.aspx|Back to
Really well made.
As with any of your choices, they will need to be set up. I did this at home with a digital level to set the camber and a couple of home made tracking plates and a couple of tape measures to set up the toe.
Hope this helps.
Ian
Posted 08 October 2016 - 11:04 AM
The others appear to do so.
But why not just modify your existing ones.
Posted 08 October 2016 - 11:24 AM
Posted 08 October 2016 - 06:58 PM
There have been a number of cases of the Minisport items failing. On safety grounds they should never be used. The problem may be due to hydrogen embrittlement because they appear to be plated.
Posted 08 October 2016 - 07:22 PM
Have you seen any of the failed parts? I'd like to know exactly how they fail as they're pretty much a copy of the KAD design, with the serrated plates - not much to go wrong there if properly installed. I ran a set on my car for over 3 years and 20K miles with no issues.....I'm curious here, not asking you to defend your statement as much as give more info.
Same with Nicklouse, why do you say they don't work?
I'm not real keen on the MiniSpares design, but as long as they work......
Edited by Magneto, 08 October 2016 - 07:25 PM.
Posted 08 October 2016 - 07:41 PM
Mini spares recently improved the deign of their brackets so I'm unsure if your talking of the new or the old ones.
Each to their own though, if I wasn't tweaking my suspension settings every five minutes I would have probably saved a few quid and enlarged the mounting holes and then welded the washers to the original brackets.
Posted 08 October 2016 - 11:05 PM
I think there is a better way of making them, with eccentric bushes, one inside the other, which can be rotated independently and then locked. I am surprised that no-one has done so.
Posted 08 October 2016 - 11:33 PM
We did something similar on the metro. But on the inboard side. Using different square insets.
Mine uses shims on the inside to add toe and a threaded adjuster on the outside to change camber.
It all comes down to total cost.
But for a road mini you really can't beat a file.
Posted 09 October 2016 - 07:18 AM
The time spent doing the above repairs and the time wasted at the 4 wheel alignment would of paid for the KAD items.
Posted 09 October 2016 - 10:15 AM
I set mine by opening up the hole on the bracket and welding on a thick washer, however the time spent adding and removing washers to get the settings close to what I wanted nearly drove me to drink. Well it actually did. The settings it at now is close to what I was wanting but not exactly so I bought a set of minisport brackets with the intention of fitting, adjusting to the setting which I think will be a lot easier than the shims then welding them to keep them there. However with what's been said on here I don't think I'll bother! She actually drives very well and is quite steady with virtually no wandering, she's on 13's and we have a lot of chipped dressing surfaces on our roads which can make a car with wide tyres wander. Maybe a case of if it's working then leave it well alone?!!
