Steering Rack Gaiter Replacement
16 replies to this topic
#1 jameslearwood
jameslearwood
  • 525 posts
  • Local Club: ALL ALONE
Posted 08 October 2016 - 02:33 PM
Hi
I have a Rover RIO 1275cc 1993
Okay so i have a resurrected project after several years sitting half done, trying to refresh my memory and figure out whats what.
I need to replace the steering rack gaiters as they have split and been damaged in the resto job.
Far as i am aware there is no problems so dont want to replace it.
Could someone point out the best way to replace the gaiters to preempt any errors.
Best way of testing to ensure there are no errors.
How do you regrease them and with what.
I already seen the threads about sub standard rubber parts so trying to find better quality ones if anyone knows of a website with them then great :D
Thank you
#2 cian
cian
  • 869 posts
  • Local Club: Minis In Northern Ireland
Posted 08 October 2016 - 03:09 PM
New ones are very stiff and they are a real pain the get over the rack so I use a heat gun to soften the rubber! Oh and the grease you use for wheel bearings will do for the rack
#3 tiger99
tiger99
  • 8,584 posts
You have a good grasp of the difficult problem, finding good gaiters. But once you have them the process is straightforward. The rack uses EP90 oil, not grease, and you just stand it on end, steering column end up, and pout in the required quantity, a third of a pint if I remember correctly, down the rack tube, before doing up the other gaiter. Please check the manual. You have to pour the oil slowly.
If doing it on the car, changing gaiters is fiddly and getting the oil in is messy, although a syringe will do it, if you loosen the outer end of the gaiter. Do it from the driver;s side. Jack the car up on that side and support it securely to help the oil go where it is wanted.
Either way, turn the steering back and forth a few times to spread the oil.
A common error is to try to put the oil in through the rack centering hole.
If you google for gaiters you may find a supplier of something suitable. Please let us know if you do. There are UK manufacturers of such things, and it may be that a material like PVC would be acceptable.
#4 jameslearwood
jameslearwood
  • 525 posts
Posted 08 October 2016 - 03:58 PM
Okay cheers for that
I could "easily" remove it as there is no engine but rather not so i don't have to mess about with alignments etc
okay google as found aceparts for the gaiter
http://www.ebay.co.u...=item5b1c9a8145
what do people think?
#5 jameslearwood
jameslearwood
  • 525 posts
Posted 08 October 2016 - 04:02 PM
what gaiters are on there are they both same diameter or different what length do i need as some sites list different ones
such as somerford mini
GSV1153 GAITER KIT, pair, with clips 1 Short (5") rubber type.  Equal diameters at large ends. button_buy_now.gif   GSV1056 GAITER KIT, pair, with clips 1 Long (7") plastic type.  Equal diameters at large ends. button_buy_now.gif   GSV1004 GAITER KIT, pair, with clips 1 Long (7") plastic type.  Different diameters at large ends.
#6 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 08 October 2016 - 05:47 PM
firstline gators last well :)
#7 tiger99
tiger99
  • 8,584 posts
Posted 08 October 2016 - 06:40 PM
I think you need to check the diameters of each end of your actual rack, which may not be original, to be sure of the required sizes.
#8 limby2000
limby2000
  • 366 posts
Posted 08 October 2016 - 07:48 PM
If you get stuck for gaitors, ive got a pair of quality nos rack gaitors that come with proper metal gaitor clips as most come with zip ties. 10 pound posted.
#9 Spider
  • 15,136 posts
Posted 08 October 2016 - 07:59 PM
If the car was driven with spilt gaiters, then I wouldn't waste time and money just replacing those.
The racks are filled with Oil, once the gaiter's split, all that runs out and the Rack runs dry. They knacker out in a very short time, so you could very well be up for a rack Replacement.
If you do end up replacing the gaiters, I don't use the zip ties that they give you with them to seal off the ends. Zip Ties don't form the correct closed shape and so they will leak. If you still have the original metal bands on there, re-use those. If not, CBS have a range of 'Flattie' Cable Ties that do form a true circle and will allow the gaiters to seal for the big ends. On the little ends, a hose clamp is best, but don't go ape tightening it.
I also apply gasket goo to the big ends to help them seal.
#10 tiger99
tiger99
  • 8,584 posts
Posted 08 October 2016 - 10:57 PM
Good point! Last time I did one, I used very large Jubilee (hose) clips because I happened to have them. You have to be careful how you orient the tightening mechanism.
But I was only refilling with oil as a precautionary measure. The gaiters were still good, and lasted for over 150000 miles. Rubber was properly made in those days.
#11 pete l
pete l
  • 1,376 posts
Posted 09 October 2016 - 07:52 AM
I heard the oil was replaced with grease quite a few years ago.
Edited by pete l, 09 October 2016 - 07:52 AM.
#12 Spider
  • 15,136 posts
Posted 09 October 2016 - 08:31 AM
They tried that here - for a short time, but went back to Oil.
#13 jameslearwood
jameslearwood
  • 525 posts
Posted 09 October 2016 - 11:28 AM
cheers car has been siting for quite a while so probably happened during thsat period also while i was doing work in the engine bay i damaged them a little so hoping the rack should be good.
will give it a good inspection and then order the gaitors.
#14 tiger99
tiger99
  • 8,584 posts
Posted 09 October 2016 - 07:40 PM
I missed the grease era. I expect it coincided with increased sales if replacement racks!
Oil is always the better lubricant. Grease is the lubricant of almost last resort when there is no possibility of keeping oil in place. Last resort, but only at relatively low stress levels, is to use certain dry bearing materials. A rack is necessarily steel on steel so oil is most appropriate.
#15 pete l
pete l
  • 1,376 posts
Posted 10 October 2016 - 08:33 AM
My 1997 MPI has grease in the rack, not oil
