I recently lost drive when I was reversing out of my driveway. After a quick inspection, clutch strip and re-build she drove fine for about 15 miles. The same thing happened again but this time I noticed that whilst Iwas not moving, I could still get a perfect readout on the speedo through the full gear range. I could even select reverse without any issues.
After a quick google inspection I read a thread posted on minifinity about the same symptoms as me and it basically said that if you were getting a readout on the speedo but no drive, it could either be the nut that secured the pinion gear, or a diff problem.
The engine is now attached to stand and the box is on the work bench. There is no 'spare' metal floating around, the nut on the end of the main shaft is still tight and in it's correct place and I have even taken the diff out and it looks perfect.
I am now stuck and wondered if anyone out there has had the same issue and aside from buying a new gearbox, how have you sorted the issue?
Mark
