I have a small spot of surface rust on my boot.
I want to have a go at removing it and painting the bare metal and then blending it back in.
All the guides on here seem to lack a little detail for complete amateurs such as myself!
So my plan of attack will be this. Please point out if I am doing anything wrong:
1) Tape off surrounding area
2) Attack rust with wire brush on the end of a drill
3) Sand down remaining rust with 240 grit sandpaper
4) Once all rust is removed, apply Krust to prevent it rusting again.
5) Apply primer filler and allow to dry.
6) Sand down primer with 600 grit sandpaper, and reapply primer.
7) Sand down again with 600 grit.
8) Apply first coat of paint, allow to dry and sand down with 800 grit sandpaper.
9) Reapply and sand paint 3 more times.
10) Apply lacquer and sand with 1200 grit paper, reapply.
11) Use a cutting paste to blend the patch in to surrounding area
Does that all sound good?
