Non Mpi Starter After Doing Oil Service
3 replies to this topic
#1 Mini97R988
Mini97R988
    Starting My Mini Up
  • 2 posts
Posted 14 October 2016 - 07:43 PM
Help needed please, I have a 97 MPi, following a reg service the car wouldn't start. After lots of checks from the usual helpful points on the forum I found a faulty starter where the wire from the solenoid to starter had broken. After referb'ing the starter and refitting today I turned the key with high hopes only to get nothing.....I've checked the battery and that's fine replaced the immobiliser battery. I've checked fuses both in car and the ones under the bonnet. Any idea, it's starting to drive me mad.......
Edited by Mini97R988, 14 October 2016 - 08:00 PM.
#2 RedRuby
RedRuby
  • 1,201 posts
  • Local Club: No
Posted 14 October 2016 - 10:14 PM
Have you by any chance dislodged the crank sensor(I think) it's on the clutch housing near to the oil filter and starter motor think the connector is coloured blue.
Edited by RedRuby, 14 October 2016 - 11:05 PM.
#3 Mini97R988
Mini97R988
    Starting My Mini Up
  • 2 posts
Posted 15 October 2016 - 08:40 PM
Looked at it, seems in place still will that stop the car turning over?
#4 Northernpower
Northernpower
    Mr. 7-Port
  • 2,414 posts
  • Name: Graham
Posted 15 October 2016 - 09:51 PM
I'd go back to basics, when you turn the key are you getting a live feed at the starter solenoid? If not, check it out further up the line at the ignition switch.
