Bolt For Central Oil Pick Up?
Best Answer Spider , 15 October 2016 - 07:58 PM
Sorry, can't see your picture.
If it's the bolt that I'm thinking of, the steady on the Oil Pick Up, I use a longer bolt, put in from underneith, nut it then stake the thread, ie, intentionally damage it with a centre punch or the like. It can be undone with tools at a latter time and you might have to replace the nut & bolt, but up can't end up somewhere it's not supposed to.
Go to the full post
Posted 15 October 2016 - 12:28 PM
I'm guessing the harmonics at high revs could cause a stress fracture in the braze, so want a bolt there - nylock will melt so.... eliptical locking nut, or drill and put a splitpin through a normal nut/bolt?
Thanks Oscar
Posted 15 October 2016 - 12:31 PM
Posted 15 October 2016 - 01:46 PM
If a Nylok would melt just use an all-steel locknut such as the Philidas type used on early Cooper drive shafts.
Posted 15 October 2016 - 07:58 PM Best Answer
Posted 15 October 2016 - 08:04 PM
It is surprising how many younger people have never heard of 'staking' a nut and bolt as a means of locking it.
We used that method on aircraft a lot in the 60's and I still use it today. Typically on the front tie-bar nut/bolt attachment to the lower suspension arm which I usually fit with the bolt upwards to make changing it easy. I use a Nyloc then stake it for good measure. As 'Moke....' says, such a lock can be undone, but a new bolt & nut will be needed every time.
Posted 15 October 2016 - 08:40 PM
One other method I did until recently was to fit a lock nut.
That's fine with Cooper S and A+ Con Rods, but, as I found out, does not work with normal A type 1275 Con Rods,,,,,,,,
Good idea on the Tie Bar Bolt, I like it.
