Clutch Straps
2 replies to this topic
#1 Northernpower
Northernpower
    Mr. 7-Port
  • 2,414 posts
  • Name: Graham
Posted 15 October 2016 - 06:35 PM
I read different opinions on how many clutch straps to fit on a high power / high torque engine. If you fit one you risk stretch, if you fit three (as recommended by Minispares) it can increase pedal pressure and increase thrust washer wear. What's the concensus?
#2 Spider
  • 15,684 posts
Posted 15 October 2016 - 07:09 PM
Fit two, it's more than enough.
You can fit 3, but you need to compensate for it by shortening the posts on the backing plate and likely adjusting the thickness of the stand off spacers on the flywheel.
#3 tiger99
tiger99
  • 8,584 posts
Posted 16 October 2016 - 09:01 AM
Also, the straps only have very slight effect on pedal pressure, probably so little that you will never notice.
