Team Dynamics Pro Race 13X7
2 replies to this topic
#1 KaneH
KaneH
  • 73 posts
Posted 17 October 2016 - 04:49 PM
Anyone on here running Pro race 1.2's? Look to be a decent lightweight(ish) single piece wheel option with a reasonable amount of positive offset to help bring Scrub Radius down. They also come in mini PCD so saves redrilling hubs to suit.
Having not seen 13's in the flesh I'd hazard a guess at issues with tie rod clearance, possibly clearance issues elsewhere? Limited lock-to-lock?
I'm not concerned about bodywork as there will be no inner wings present and wings/arches can be modified to accommodate fitting. Also the front sub frame will be getting modified to move the suspension pickups outboard in an effort to increase front track width without the need for spacers.
#2 Mini 360
Mini 360
  • 4,933 posts
  • Local Club: Independent
Posted 18 October 2016 - 05:32 PM
You need this I think
http://www.willtheyfit.com
#3 KaneH
KaneH
  • 73 posts
Posted 18 October 2016 - 06:43 PM
Doesn't really help as all that gives is the change in static clearance when wheels are sat parallel. Thanks for the suggestion though.
