mini camshaft
10 replies to this topic
#1 andyprince111
andyprince111
  • 39 posts
Posted 10 September 2006 - 08:03 PM
hi,
what you all think of this camshaft any good for my 1380 engine im building? gonig to be fast road spec engine.
andy
sorry heres the link
http://cgi.ebay.co.u...1QQcmdZViewItem
#2 biggav
biggav
  • 5,830 posts
  • Local Club: South Central
i have a 286 which is great fun!!!!
#3 andyprince111
andyprince111
  • 39 posts
Posted 10 September 2006 - 08:05 PM
so what u thnk of that 1 any good? and what price u think if will go for?
#4 minimadjonesy
minimadjonesy
  • 6,417 posts
  • Local Club: SMAC
Posted 10 September 2006 - 09:03 PM
286 is a very good cam but can be a little lumpy at low revs but at over 3000rpm it's very very fun!! :w00t:
#5 Dog
Dog
    Deathwish Fairy
  • 9,550 posts
  • Local Club: Shatrats.com
Posted 10 September 2006 - 10:39 PM
How about a Morspeed ph2 (trackday)
Pulls from about 2k, and dies around 7k... simular to the 286, only you get fun lower down in the rev band :w00t:
#6 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 11 September 2006 - 08:04 AM
the 731 is an in-betweenie, 268° duration with a .3" cam lift... personally, would give a decent pull, but not as sweet as an SW5/10 or 276/286.
#7 KW5670
KW5670
  • 11 posts
  • Local Club: HK Mini Fans Club
Posted 11 September 2006 - 12:49 PM
Hi! First time joining the forum.
My car is equipped with the SW5i. Frankly speaking, it does hesistates to pull below 1K rpm. After 1K rpm onward, it pulls smoothly. The SW5i is a camshaft which delivers linear power. Unlike the 286 cam, which gives you big torque suddently....
#8 Gizzum
Gizzum
  • 554 posts
  • Local Club: None atm
Posted 14 September 2006 - 02:29 PM
O.K. then, so far weve got about half a dozen cams and we are still on the first page. I am thinking bout a new cam and this post has got me more confused than a confused thing on national confusion day! I was looking at either the SW5 or a 276/266. Do you have to replace the followers and rods when sticking a new cam in? or can you go with the old ones. And would it be good to replace the timing chain for an uprated vernier duplex jobby?
#9 KW5670
KW5670
  • 11 posts
Posted 14 September 2006 - 02:46 PM
Replacing the cam followers is a must... in order to ensure the camshaft run perfectly. Well, new cam followers are not expansive anyway. Better be safe than sorry....
As for the rods, I assume you are referring to the con rods. I did not have them replaced. Just need to check and ensure they are straight.
As you are probably doing the engine rebuild at the same time, your engine may need a new timing chain anway.... So, maybe you can consider upgrading to duplex timing chain.
#10 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 14 September 2006 - 02:58 PM
con rods
Pushrods you mean ( and no don't need replacing unless excessively worn ) if you conrods are bent then your engines in bits !
As for the choice of cam, there are loads to choose from and your choice will depend on your requirements... The most obvious of which will be the need to get the car through an emissions test at MOT time...
The SW5 is said to be the most MOT friendly when tuned of the performance cams, especially if your vehicle needs to take the cat test. I'm a kent bigget, never used any manufacturer cam, the 276 was a nice road cam, using a 290 at the mo, and that's stunning, but going to try a piper300 in the next build which should be fairly lively.
#11 neil_g
neil_g
  • 880 posts
Posted 14 September 2006 - 03:00 PM
Kent MD286 over here too, just to give you an idea of what sort of drive it gives (see sig for a quick rundown of my spec, also 1.5 r/rockers, straight cuts etc etc)
http://images7.fotki...DSC01803-vi.jpg
blue thin line is torque
red line is power @ wheels
green line is power @ fly (est)
Edited by neil_g, 14 September 2006 - 03:01 PM.
