Brake Master Cylinders
3 replies to this topic
#1 warning634
warning634
  • 489 posts
Posted 21 October 2016 - 06:03 PM
Hi chaps
I currently have fitted the KAD duel master cylinder set up.  I would like to change this, as it takes up too much room in the engine bay.
The mini is used for competition use, what recommendations can you guys give me to replace this KAD set up.
the front brakes are cooper S, grooved discs with carbon pads, rear brakes, minifins not sure what size rear cylinders with standard shoes.
Kevin
#2 nicklouse
  • 18,600 posts
Posted 21 October 2016 - 07:11 PM
Any really.
What use? Do you need dual circuit of can a single do?
#3 Spyder
Spyder
  • 20 posts
Posted 26 October 2016 - 08:14 PM
Related Q - can I fit a hydraulic handbrake to a single circuit system?
#4 nicklouse
  • 18,600 posts
Posted 26 October 2016 - 08:45 PM
Yes but you will need the pressure regulator before it and a T piece in the rear.
You will also need a standard handbrake for road use.
Edited by nicklouse, 26 October 2016 - 09:32 PM.
