What Happens When You Reach The Rev Limit Of Your A-Series?
Posted 24 October 2016 - 02:13 AM
What happens when you rev your mini engine to it's limit?
This may seem like a stupid question but I have been considering the future build of my new mini project. When I had my last mini, a 998 with 12g940 head and 266 cam it would lean out like crazy at about 5-5500rpm. It now occurs to me that perhaps this was not a carb/tuning issue, rather just the engine running out of puff?
Does that line up with other people's knowledge experience? Particularly those who have dyno'd their cars and know where their power curve tales off.
Posted 24 October 2016 - 03:59 AM
My dads slalom race Mini has its peak Power at 7220 rpm, rev limiter was at 8.5k and it has been hit quite q few Times.
Posted 24 October 2016 - 05:45 AM
That sounds more like a tuning problem or the fuel pump has reached it's peak. Assuming it is built correctly and has the appropriate valve springs etc you should be able to do more revs than that safely..
Posted 24 October 2016 - 06:00 AM
I was running an HIF44 at the time.
I just thought it would be worth getting feedback on as perhaps I was just expecting too much from the 266, but it really seemed like a well behaved cam profile
Posted 24 October 2016 - 06:45 AM
If its a mechanical fuel pump it shouldnt be an issue at those revs, mine runs 110 ATF with one. Valve bounce and a tailing off of power when your past the cams powerband.
Posted 24 October 2016 - 08:00 AM
poor set up.
sounds like wrong needle.
what limits the max RPM is generally valve train bounce this varies with cams and springs used.
Posted 24 October 2016 - 09:33 AM
you will get valve bounce.
