Weber Progression Holes
Posted 27 October 2016 - 11:44 AM
Posted 27 October 2016 - 12:45 PM
You don't say if you are buying the carb new or second hand. Obviously if buying new, you would expect the supplier to provide the basic specification of carb for your particular requirements.
However, if buying second, third or fourth hand, you may have a carb originally fitted to another model that even started out with the wrong number and size of progression holes and each new owner has probably added or modified the carb to their requirements.
I am sure that someone with a similar spec engine to yours will be able to help, but in the meantime I think I would contact Webcon ([email protected] or call 01932 787100) and ask them the recommended spec of carb for your engine. Then if buying second hand you can check if the carb spec is correct or can be modified to work with your engine.
Always bear in mind that when setting up the engine on a rolling road an engineer used to tuning Webers would be able to fine tune your carb, including progression holes, providing it has not been previously, too molested.
Posted 27 October 2016 - 02:17 PM
Edited by Dusky, 27 October 2016 - 02:18 PM.
Posted 27 October 2016 - 05:22 PM
Thank you very much for the answers guys
I will most likely be buying the carb new, although they crop up from time to time on fleabay for a good price, so I will be keeping an eye out on there too. I won't be modifying the carb, so wanted to get the correct number of progression holes to suit the engine build, as like you say it is only remedied using a mill/pillar drill. As it is a track day/ summer weekend car, fuel economy is not something I am worried about. I basically want it to perform the best it can.
I was just wondering what model weber other people use with similar specced engines.
Posted 27 October 2016 - 05:26 PM
The dcoe 152G would Be my choice for a road going toy car.
Hope this helps
