I know there's only me interrested in this, but I found another thread that mentions this:
http://www.theminifo...be-looking-for/
Near the bottom someone implies the "lugs" have an effect on fuel distribution, saying:
I tried porting the SPi inlet manifold and found that removing the lugs gave fueling problems between the inner and outer cylinders.
Unfortunately I can do little to help, but I'm currently taking my engine out my SPi and I am glad I found this thread as I was going to do some porting to my inlet but I'll leave it alone now!
Hope you find a colution/definitive answer and you can make another awesome product (I follow your Podifold thread, I find your work amazing). Good luck!
Cameron.
edit: quickly thinking, no idea if this would work, but could this be tested using 2 different manifolds 1 with the C-shaped bits and 1 without.. on an engine with a scatter pattern cam and one without? Because aren't scatter pattern cams designed to minimise the effect of charge robbing and in effect may help determine whether the C-shaped inserts are to help with this problem?
Edited by RooBoonix, 19 November 2016 - 03:14 PM.
