Rear light cluster
5 replies to this topic
#1 Roo
Roo
    The Queen Of The Curly Wurly
  • 3,656 posts
Posted 11 September 2006 - 01:00 PM
Hi
Since my accident i've had my car fixed, which ment new rear lights on the passenger side. However i noticed yesterday that my rear light wasn't working. the break light is fine but the rear just won't work. I've checked the bulb and its fine and i've checked the wiring but can't find what is wrong. Has a fuse gone or is there faulty wiring somewhere?
Hope you can help.
Roo
Edited by Roo, 11 September 2006 - 01:02 PM.
#2 Retro_10s
Retro_10s
    Moderator
  • 10,138 posts
Posted 11 September 2006 - 01:13 PM
it's worth checking the fuses yep, also check the earth points around the car, give em a good WD40'ing
sounds like it's an earth, as i thought the rear lights had a fuse to share, unless there's inline ones... hmm
** wanders off to garage to stare at wiring on my mini.**
#3 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 11 September 2006 - 02:31 PM
you do know that there should be 2 filaments in the bulb's dont you ?
#4 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 11 September 2006 - 02:33 PM
swap the bulbs over left to right, if the problem stays with the unit then it's a wiring problem, if it moves with the bulb, then replace the bulb.
#5 minipip
minipip
  • 1,591 posts
  • Local Club: TMF SE
Posted 11 September 2006 - 03:55 PM
id say fuses! and check all the eaths have good metal to metal contact!
#6 Roo
Roo
  • 3,656 posts
Posted 11 September 2006 - 04:36 PM
Yeah i realised that the bulb would go in either way and noticed that only the one way would allow both contacts to be connected. would not work either way.
Roo
