Headlining Glue
8 replies to this topic
#1 Minitransition
Minitransition
  • 65 posts
Posted 05 November 2016 - 09:22 AM
Hi, As I can't find a section for 'interior trim' - can anyone help here please?
Just about to refit headlining - vinyl 1989 type. All cleaned up now and wondered what adhesive to use.
I don't want to use a spray as they go everywhere ! Evo stick is too thick as I would  like to brush it on the sides and front / back.
Anyone had a good result that doesn't melt the vinyl?
#2 Dusky
Dusky
  • 5,322 posts
Posted 05 November 2016 - 09:36 AM
Pattex contact glue, temp resistant up to 110°c
#3 Minitransition
Minitransition
  • 65 posts
Posted 05 November 2016 - 09:47 AM
Thanks, use guide for Pattex says not suitable for flexible PVC.
Is it spreadable unlike Evo-stick that is like smoothing out horse dung??
:nuke:
#4 Dusky
Dusky
  • 5,322 posts
Posted 05 November 2016 - 12:02 PM
I used it for my headlining and vinyl roof , brushes like thick paint
#5 Alice Dooper
Alice Dooper
  • 391 posts
  • Local Club: Minis in Northern Ireland
Posted 05 November 2016 - 10:47 PM
I used Everbuild Powergrip double sided tape and it was brilliant.
No flafing about with open time of glue, goes only where you want it and is way quicker.
Best way I could describe it is an extremely strong gel glue, reinforced with a very thin fabric and all on a roll. It comes in a few different widths, I used 5mm.
#6 JonnyAlpha
JonnyAlpha
  • 2,748 posts
  • Local Club: Exmoor Minis
Posted 06 November 2016 - 08:07 AM
I was advised to use Evostick Contact Adhesive. Comes in a tin and ScrewFix do it for about £4 for 250ml.
It's a bit messy but I brushed it on with a small brush. Glue both the material and the area where the material is to be fixed, leave for 5 min and then fix together.
I used it to fit a refurbished headlining and it worked brilliantly didn't even need to clamp the headling while the glue set!
Edited by JonnyAlpha, 06 November 2016 - 08:09 AM.
#7 tiger99
tiger99
  • 8,584 posts
Posted 06 November 2016 - 05:17 PM
I don't know what the factory used but my 1984 model was a right mess.
I hate doing headlinings. With experience of adhesives on other things, I am of the opinion that the suggestion about adhesive tape has much to commend it. Probably no downside. Goes only where you want it. I don't know the particular material suggested, but many of them stick really well.
#8 andyt
andyt
  • 375 posts
  • Local Club: cooper register
Posted 06 November 2016 - 06:26 PM
You have to be carefull not to use the solvent based evo stik as it says not to use it with cellulose paint, i nearly got caught out by this and had to buy the solvent free stuff which was not that great.
#9 cal844
cal844
  • 9,637 posts
  • Local Club: TFMOC
Posted 06 November 2016 - 08:43 PM
All we did was go to a carpet shop, bought an aerosol can but sprayed it into the cap then brushed it on... You have to be quick though as it can go off quick
