Brake Lights Not Working
2 replies to this topic
#1 Moggyman
Moggyman
  • 15 posts
Posted 06 November 2016 - 06:12 PM
Hi everyone,
I recently bought a mk2 mini cooper but on the drive home my wife who was behind told me my brake lights
were not working, on arriving home i checked the wiring and the bulbs and also the earth wires, and i'm a bit
stumped!  could anyone give me any ideas please?
Thanks Andy
#2 maximas
maximas
  • 108 posts
Posted 06 November 2016 - 06:17 PM
Try the switch behind the brake pedal...sometimes the wire has come off...look at the easy fix first...
#3 Will16
Will16
    Wants a custom member title
  • 1,090 posts
Posted 06 November 2016 - 06:58 PM
Your car is probably on single line brakes, so the switch will be on the subframe, drivers side, where the brake lines split to go to the caliper and round to the other side. To check that the brake lights work, un plug the two spade connectors on the switch and connect them together with the ignition on, the brake lights should come on. If they do, its the switch, if they dont, its something else
switch looks like this:
http://www.minispare...ic/C16062A.aspx
also another oxfordshire member  :thumbsup:
Edited by Will16, 06 November 2016 - 06:59 PM.
