Remove Tacho Needle
10 replies to this topic
#1 ausyonline
ausyonline
  • 12 posts
Posted 09 November 2016 - 02:21 AM
I'm trying to replace my gauge faces with the cooper faces on an 88 instrument cluster and have been able to do the speedo and temp gauges but simply can not get the tacho gauge off and dont want to risk breaking it so is any one able to offer some tips?
#2 tiger99
tiger99
  • 8,584 posts
Posted 09 November 2016 - 12:27 PM
You probably need a pointer puller which will be just like any other puller but much smaller. In other words, a device where you tighten screw(s) gently to do the pulling rather than trying to yank it off with pliers, for example, which you rightly are wary of doing.
You would need to know how the pointer is attached and whether it is safe to pull on the shaft bearings. If the bearings are ok, the tool might be a simple slotted plate that slips behind the hub of the pointer with two small, padded screws to jack it against the instrument faceplate or a strong point like it's fixing screws.
#3 GraemeC
GraemeC
  • 7,451 posts
Posted 09 November 2016 - 02:06 PM
That said, the age old method is to gently use a fork to lever it off.
#4 zero_wlv
zero_wlv
  • 126 posts
Posted 09 November 2016 - 04:31 PM
I had to replace the faces on my '88 Nippon Seiki instrument cluster and I found that the needles just pulled off by hand  (I think I had to use a flathead screwdriver to lever one of them off).    All the needles came off and went back on easily.
I don't know if you've got as far as dismantling the fuel/temp gauge yet,  but if you do,  be careful with it   -   one of the backscrews is actually holding the fuel gauge mechanism together.    When I unscrewed mine,  the whole mechanism disintegrated and I had to work out how to fit it all back together.
#5 JBW
JBW
  • 157 posts
  • Local Club: Mini Fixers
Posted 09 November 2016 - 07:26 PM
I used a "forked" trim removal tool & an old plastic card (credit card type" to spread the load on the dial face, I have Nippon Seiki gauge's & it worked fine on 2 different sets.
#6 69k1100
69k1100
  • 376 posts
Posted 09 November 2016 - 08:08 PM
https://youtu.be/BesSK67Mzms
This guy uses a pair of pry bars and a plastic bag to protect the face.
#7 69k1100
69k1100
  • 376 posts
#8 ausyonline
ausyonline
  • 12 posts
Posted 09 November 2016 - 09:44 PM
Thanks for the tips everyone! I will persist gently and see if i can get one of those fork trim removal tools.
#9 ausyonline
ausyonline
  • 12 posts
Posted 09 November 2016 - 09:47 PM
Good tip thanks I will make sure I am careful when doing this!
#10 ausyonline
ausyonline
  • 12 posts
Posted 10 November 2016 - 09:17 AM
It took a lot of gentle prying but I got it off finally - thanks again for the tips !
Edited by ausyonline, 10 November 2016 - 09:19 AM.
#11 andyt
andyt
  • 375 posts
  • Local Club: cooper register
Posted 10 November 2016 - 01:28 PM
A piece of old circuit board with a slot in usually works.
