When To Use Thread Lock Inside An Engine?
6 replies to this topic
#1 rally1380
rally1380
  • 1,893 posts
Posted 09 November 2016 - 09:18 AM
(Apology's if this has been discussed before....I've started this thread on another forum, and thought i'd get the opinion on here too.....there are more experts on here!!!!)
Bit of a wide ranging question this as it is relevant to every engine build......as per title really, when (if ever) do you use a thread lock solution (Loctite as an example) on nuts and bolts inside an engine?
About to start doing final assembly and want to know whether or not to use the stuff on bolts like main caps and big ends (as an example). I know there wasn't any on them originally, but seeing as some fixings do like to shake loose over time (not that I've ever had a main cap bolt come loose) is it best to apply some blue gloop whilst assembling or can this affect the torqueing process?
#2 Spider
  • 15,201 posts
Posted 09 November 2016 - 09:55 AM
I don't use a thread locker on much inside the engine. Off hand, the Cam Nut, The Harmonic Damper Bolt, Flywheel Bolt - basically the stuff that had the locktabs from the factory and I no longer use the locktabs.
The other fasteners, I clean the threads with thinners and either oil them or use ARP's lube as appropriate.
I also use locitie on all the plugs too, not as a locker, but a sealant,
#3 Ethel
  • 26,112 posts
Posted 09 November 2016 - 10:43 AM
... so ones that are in the centre of spinning bits and are at risk of being unscrewed. Ones that hold static bits together rely on tension to keep them in place and resist fatigue from being stretched. The correct tension is a product of the fitting torque which will rely on the correct, or lack of any, lube.
#4 Mini Manannán
Mini Manannán
  • 2,860 posts
  • Local Club: man Estate
Posted 09 November 2016 - 11:00 AM
I also use loctite on all the plugs too, not as a locker, but a sealant,
The spark plugs Chris?
#5 GraemeC
GraemeC
  • 7,446 posts
Posted 09 November 2016 - 11:03 AM
Core plugs I would presume
#6 Spider
  • 15,201 posts
Posted 09 November 2016 - 11:12 AM
Bhahaha,,, nah, not the spark plugs mate.
The Freeze Plugs and Oil Gallery Plugs. Also, the Oil Switch / Gauge Adaptor too.
#7 Mini Manannán
Mini Manannán
  • 2,860 posts
Posted 09 November 2016 - 11:29 AM
Thought that was a bit extreme, even for you Chris!!! :D
