I've got a few leaks. I did a cursory inspection a few days ago and thought it was the gearbox rod selector that was leaking, so I bought the seal kit for that and put the car on axle stands to sort it out. At that point I was able to have a proper inspection under the car and now think my leak(s) are more substantial than that. I've attached a few pics, it looks like I'm losing oil from the drive shaft pot joints (Is that what they're called?)
But there's oil everywhere, if it was leaking here would the oil get plastered everywhere or do I have more issues? Are these all easy leaks to fix? I've never had the drive shafts out, so some advice on replacing those seals would be useful!
Anyway, some pics:
Rocker cover:
DSC_0754 by Paul Rockliffe, on Flickr
Oil pressure and filter return:
DSC_0755 by Paul Rockliffe, on Flickr
Pattern of drips under the car:
DSC_0756 by Paul Rockliffe, on Flickr
Under the clutch:
DSC_0758 by Paul Rockliffe, on Flickr
Gearbox rod selector:
DSC_0760 by Paul Rockliffe, on Flickr
Differential cover:
DSC_0761 by Paul Rockliffe, on Flick
Advice great fully received!
