Innocenti Cooper S 1974 Servo Problems
2 replies to this topic
#1 dave houston
dave houston
    Starting My Mini Up
  • 3 posts
Posted 14 November 2016 - 12:11 PM
Hi there
i am having problems with my 1974 innocenti cooper s servo unit , as soon as the engine is started the front brakes lock up , if i disconnect the vacuum pipe the brakes free up and the engine revs increase quite a bit.
Has anybody got an idea whats went wrong and how to remidy it.
look forward to hearing from you
cheers dave
#2 panky
panky
  • 1,793 posts
Posted 14 November 2016 - 12:15 PM
It sounds like there is an air leak into the space behind the diaphragm, possibly the air valve. If it is leaking then it could be possible that the brakes operate by themselves
#3 DomCr250
DomCr250
  • 667 posts
  • Local Club: 16V mini club
Posted 14 November 2016 - 01:16 PM
I had this on my old 1969 1275GT which I think had a similar type of remote servo, I swapped mine out for one I had lying about at the time.
One thing worth pointing out is the mine had also sucked up a decent amount of brake fluid over the years, so be careful when removing it from the car and watch for drips, I missed one and it landed on the wing.
