Lower Arm Bushes, Am I Stupid Or What
9 replies to this topic
#1 dasupersprint
dasupersprint
  • 848 posts
Posted 15 November 2016 - 03:57 PM
I bought lower arm bushes from Minispares, they have a metal sleeve in them . Part 21A1882MS. They say it's better with the sleeve.
Except, the sleeve doesn't fit, it's too small, it has the same ext. diameter as the lower arm pin. I removed the sleeve and the bush fits perfectly.
What am I missing?
Also, do they need grease?
Edited by dasupersprint, 15 November 2016 - 03:57 PM.
#2 Carlos W
Carlos W
  • 10,115 posts
Posted 15 November 2016 - 03:58 PM
Are you sure there's not already a sleeve rusted on there?
Mine was......
#3 nicklouse
  • 18,999 posts
Posted 15 November 2016 - 04:01 PM
As above. Remove the old one.
#4 dasupersprint
dasupersprint
  • 848 posts
Posted 15 November 2016 - 04:04 PM
Really?! I'll have a look and I hope you're right
#5 nicklouse
  • 18,999 posts
Posted 15 November 2016 - 04:32 PM
we are.
#6 Spider
  • 15,686 posts
Posted 15 November 2016 - 05:29 PM
Very common that they are rusted as the other guys have said.
I put a light lick of chassis grease on the pin when assembling, not for lube, but as a rust preventer - be sure you don't get any on the rubber!  And for the rubber, to assemble them in to the Arm, I use Rubber Grease.
I think there was a thread on this in the past week or so.
#7 Carlos W
Carlos W
  • 10,115 posts
Posted 15 November 2016 - 10:38 PM
Its certainly not the first thread I've seen over the years, I think I've got a pair in the garage like it too.
#8 tiger99
tiger99
  • 8,584 posts
Posted 16 November 2016 - 04:02 PM
One reason that the pins rust so badly within the bush is that, following a suggestion in a well-known monthly comic about 30 years ago, people at one time were using washing up liquid to lubricate the bushes to aid fitting. Done it myself, which I came to regret. Apparently the leading brand, the long lasting one, which in all fairness does clean the dishes very well, maybe all others too, contains a large proportion of salt. We know what that does to steel!
Likewise don't use automotive products to clean the dishes!
I used to have a rattle can of rubber lubricant from Halfords, which works, as does silicone grease in spray or normal form. But I would advise the non-silicone rubber lubricant. Silicones tend to get everywhere and you may have to repaint part of the car eventually. Silicones, although harmless to the car, really mess up a paint job. Best not allowed in the garage, although I generally do use silicone brake fluid, carefully.
If all else fails, plain old-fashioned, non-detergent soap does the job fairly well. Don't use DOT4 brake fluid or even red rubber grease, as they will strip paint on the subframe.
#9 dasupersprint
dasupersprint
  • 848 posts
Posted 17 November 2016 - 01:38 PM
we are.
You were. I love this forum
#10 Carlos W
Carlos W
  • 10,115 posts
Posted 17 November 2016 - 02:01 PM
we are.
The only reason I knew is because I'd done the same
