1990 Rover Mini Wont Start
Best Answer Its a min , 17 November 2016 - 11:39 PM
Now I don't know if Japanese spec mini's were wired differently but try cleaning the wires properly and double check the colours.
if the 'green' wire is actually green/blue, it should be from the temperature sender unit located in the engine block above the alternator.
The 'yellow' wire is probably white/yellow and connects the starter solenoid to the coil (+).
Hope this helps.
Go to the full post
5 replies to this topic
#1 slowsupra
slowsupra
    Starting My Mini Up
  • 3 posts
Posted 17 November 2016 - 08:33 PM
1. Year of your vehicle 1990
2. Model of your vehicle Rover Mini
Hello, I imported a  Rover mini  from japan to here in the states and it won't start. It cranked over and ran fine in japan with no issues. The day before I picked it up the car, the idiots i bought the car from were fooling with the coil and don't know how it went. Now the car won't start. It cranks but wont turn over. These wires are unplugged and I don't want to put them in the incorrect spot.
I'm getting spark and fuel.
This is my first carbureted car so this is a little bit of a learning curve.
The green and yellow wires were unplugged.
Edited by slowsupra, 17 November 2016 - 08:48 PM.
#2 GraemeC
GraemeC
  • 7,467 posts
Posted 17 November 2016 - 08:43 PM
Are there 2 coils?
#3 slowsupra
slowsupra
    Starting My Mini Up
  • 3 posts
Posted 17 November 2016 - 08:48 PM
Sorry, I added a incorrect picture.
#4 Its a min
Its a min
  • 284 posts
Posted 17 November 2016 - 11:39 PM   Best Answer
Hope this helps.
#5 Its a min
Its a min
  • 284 posts
Posted 17 November 2016 - 11:59 PM
Hi,
Forgot to mention that being a 1990 model (and looking at the picture) you probably have a ballast wire (pink/white). If the white/yellow wire isn't connected to the coil, you will not be cranking at 12 so probably not enough power to start the engine.
Do a search for 'ballast' on the forums as there are plenty of threads on the pros and cons.
Good luck.
#6 slowsupra
slowsupra
    Starting My Mini Up
  • 3 posts
Posted 18 November 2016 - 01:37 AM
Thank you kind sir! they were the correct spade locations and now it runs.
