Facet Adjustable Fpr
5 replies to this topic
#1 minifreek1
minifreek1
  • 1,260 posts
  • Local Club: S.U.N.M.O.C
Posted 21 November 2016 - 07:39 PM
I have in my shed of many things, a Facet adjustable FPR with pressure guage attached and all pipework... I know it works as I had it fitted to my old Vectra and was just wondering if it might work with the SPi engine in my Mini...?
Iv not really gone into any depths of looking around my engine except for when I had running issues with it and it got cured quickly with some help off member on here offering advice...
Im only looking to see if it will give my Mini a bit more oomph, I know it did my Vectra....
#2 nicklouse
  • 18,658 posts
Posted 21 November 2016 - 07:55 PM
A fuel pump can not give any more power. It just supplies fuel it does not meter it out.
#3 minifreek1
minifreek1
  • 1,260 posts
Posted 22 November 2016 - 07:26 AM
Its a Fuel Pressure Regulator not a fuel pump....?
#4 bluedragon
bluedragon
  • 287 posts
Posted 23 November 2016 - 10:29 AM
For a modified fuel injected Mini, it might help. If the mods increased airflow and the engine is now running too lean, increased fuel pressure can give the effect of larger fuel injectors, increasing fuelling and thus improving power.
The drawbacks are that unless the fuel pressure regulator is variable and can adjust to engine vacuum (a rarity) it may well overfuel the engine at lower throttle settings, killing off your fuel economy. FPRs that adjust to boost pressure are much more common and are a time-honored trick to get more fuel in to support a supercharged engine (and don't kill part-throttle economy because they don't raise the pressure when they don't sense turbo boost.)
I'm not sure that this trick would work on an SPI Mini - more experienced people would need to confirm. With just a single central injector, an SPI Mini is a lot like an electronic carburetor, and increasing fuelling at a central point might just make the fuel pool up in the manifold.
The trick does work on MPI minis, with the problems listed above (the original Cooper "90 hp" kits for the MPI had modified FPRs to supply the needed fuel.)
If the SPI is stock, the FPR IMHO would do nothing beneficial. If it actually helped a sick SPI Mini, it's probably covering up for some other failing in the system.
Dave
#5 Steve220
Steve220
  • 5,063 posts
  • Local Club: BMC
Posted 23 November 2016 - 02:16 PM
Spi works at a low fuel pressure and doesn't need anymore. It also doesn't have a fuel rail as such, it's internally regulated from what I remember.
#6 minifreek1
minifreek1
  • 1,260 posts
Posted 23 November 2016 - 04:56 PM
Thanks for the reply Blue Dragon, much appreciated... it is adjustable, from 0 BAR up to IIRC 6 BAR....
Also thanks to Steve220 too, its basically not going to work... thats cleared that up :)
Thanks for the replies gents :)
