Or at least I don't think so....
Re-connected all the wires which I removed when swapping engine from 998 to 1275, connected fuel line (which is working as I had forgotten to connect at first so fuel was pumping out of hose...doh!)
I'm using same dizzy from 998 but have new leads and new coil. Connected black/white leads to neg of coil and white/pink and yellow/white to Positive of coil (that's how I'd labelled them anyway....!)
Fitted vac line from dizzy to card
Have the positive lead from dizzy connected along with the negative too. These are to wires from the loom which I'd labelled dizzy - and dizzy + so I know they're correct also.
But no engine start!! No a flicker or cough so I know it's the spark thats the issue.
Where do I start looking....?
