Lowered Shocks - Standard Mount Or Lowered?
11 replies to this topic
#1 MiniMadMan1996
MiniMadMan1996
  • 48 posts
  • Local Club: Cinque Ports Mini Owners Club
Posted 28 November 2016 - 05:25 PM
Right ok so I've got myself a little confused here, I've given my dad a few xmas present ideas and one of them was the DSN billet shocker mounts, but they're a direct replacment for the standard ones. Now I'm building a Miglia style car so getting it low is a must! So if I use say for instance Gaz lowered shocks with the DSN billet mounts, will there be any problems? Or will I have to use Lowered mounts with lowered shocks? Because these billet mounts are £75 (Yes I know thats expensive but I'm going for a removable front so I gotta have some trick parts) And I don't want my dad to buy them to then only find out they're no good... Because I've read a few posts about people running lowered shocks on standard mounts and things crash together or something? So any help and or definitive answers will be greatly appreciated!
Regards, Sean :)
#2 Will16
Will16
    Wants a custom member title
  • 1,090 posts
Posted 28 November 2016 - 05:37 PM
The 'lowered' mounts (below) are to use standard height shocks but to still lower the car,
http://www.minispare.../C-AJJ3359.aspx
DSN mounts will be fine with lowered shocks and low ride height  :thumbsup:
If you are going really really low, you could use the 'lowered' mounts with lowered shocks, have a look in my thread here at my shock travel!
http://www.theminifo...mini/?p=3402944
#3 MiniMadMan1996
MiniMadMan1996
  • 48 posts
Posted 28 November 2016 - 05:44 PM
Brilliant!! I'm going pretty low, but the car is in a million pieces at the moment so I have no idea how low I really want to go without scraping exhausts etc Because i'm hoping to use a proper miglia exhaust but making some custom pipe work to make it a side exit rather than a centre exit so It'll naturally hang lower, but thank you for clearing things up!! Really Appreciate it!
#4 b_sdaddy
b_sdaddy
  • 643 posts
Posted 28 November 2016 - 06:01 PM
Sorry to barge in on you like this, but is there a 'thread' anywhere called; 'Idiots guide to mini suspension'' What I'm after is the suspension equivalent to Vizards engine tuning bible. I'm running a completely standard set-up but everytime I get to see threads/photos like this, I just want to go into the garage & start playing! With my mini staying put, as a std. 998, need a project!
#5 timmy850
timmy850
  • 3,397 posts
  • Local Club: MITG
Posted 28 November 2016 - 10:07 PM
Vizard did an earlier book called "How to modify your Mini" which had some information on suspension from memory. Pretty old school, but a good read
#6 paulrockliffe
paulrockliffe
  • 1,763 posts
Posted 28 November 2016 - 10:11 PM
It's a cool book, worth a read, though I can't remember what it says about suspension.
If the lowered shock mounts are for standard shocks, does that mean they actually move the mounting points higher?
#7 nicklouse
  • 18,724 posts
Posted 28 November 2016 - 11:10 PM
Soooooo
How low are you going?
How to deal with lowered cars and shocks.
Make the shocks sorter and have a shorter stroke. Remember to fit 1/4" spacers under rebound buffers.
Use standard shocks but mount them higher in the car. Remember to fit 1/4" spacers under the rebound buffers.
One thing to remember a miglia look car will not nice to drive on any road.
#8 timmy850
timmy850
  • 3,397 posts
  • Local Club: MITG
Posted 28 November 2016 - 11:17 PM
Std ones have the bolt in the middle.
Lowered ones are offset higher (and inwards) as described
http://www.minispare...74.aspx|Back to
#9 Carlos W
Carlos W
  • 10,114 posts
Posted 29 November 2016 - 07:32 AM
Remember, shocks and shock mounts don't change the ride height. You'll need hilos for that.
The height you set your hilos at will determine whether you need to run different shocks and or shock mounts.
If you start bouncing off the bump stops the car will be awful to drive and you'll start breaking things
#10 Brian Cartmell
Brian Cartmell
    Starting My Mini Up
  • 3 posts
Posted 15 January 2018 - 06:31 PM
So I'm building my 61 right now, I have the lowered upper shock mounts and lowered Pro-tech shocks and brand new red dot cones on hilos, the shocks will not fit, about a inch to long, any ideas will be appreciated ???
Edited by Brian Cartmell, 15 January 2018 - 06:32 PM.
#11 Tupers
Tupers
  • 4,158 posts
Posted 15 January 2018 - 06:46 PM
Lowered damper mounts are supposed to be used with standard length dampers on a lowered cars as they move the mounting pin up to stop the standard length dampers from bottoming out.
If you are running lowered dampers you need standard damper mounts.
#12 KTS
KTS
  • 2,470 posts
Posted 16 January 2018 - 12:09 AM
As I understand it, this setup should make the damper too short not too long. Daft question, but are the mounts installed the right way round ?
Edited by KTS, 16 January 2018 - 12:11 AM.
