Need Help To Identify Ecu Connector And Wires
7 replies to this topic
#1 hungdynasty
hungdynasty
  • 175 posts
Posted 01 December 2016 - 02:40 PM
1998 Japan spi , my ecu has 2 connectors, this one is the small one with 18 pins. I cannot find this connector on the circuit diagram so I cannot identify the wires on it. I took a picture of this connector, the top left with red dot is a yellow wire, the other two are black wires, however are disconnected. Thanks a lot.
WhatsApp%20Image%202016-11-30%20at%2012.
#2 genpop
genpop
  • 530 posts
Posted 01 December 2016 - 06:44 PM
Hello,
maybe page 12 and 13 will help
#3 hungdynasty
hungdynasty
  • 175 posts
Posted 02 December 2016 - 12:06 PM
Hello,
So that should be pin 5(disconnected) OS relay driver ,8(disconnected)Turbo air pressure solenoid ,and 18 Camshaft sensor. OS means oxygen sensor? And I don't think my spi has camdhaft sensor is it correct?
#4 tmsmini
tmsmini
  • 735 posts
  • Local Club: MOASF
Posted 02 December 2016 - 04:45 PM
Yes, you should have this in place of the camshaft sensor:
http://www.somerford...roducts_id=5243
The listing above looks like it is from the Haynes injection manual that covers the MEMS systems. There are some nuances to the Japanese MEMS based cars that Haynes may not have 100% correct.
In another thread there was a post indicating that the crank sensor wiring was different between the auto and manual versions that probably took a very close examination of the wiring diagrams to discover and verify.
Terry
#5 hungdynasty
hungdynasty
  • 175 posts
Posted 03 December 2016 - 11:57 AM
Terry
I think I find it, this connector is probably C161 in circuit diagram, to ignition coil.
#6 Skipp
Skipp
  • 20 posts
Posted 03 December 2016 - 12:34 PM
Hello mate is your manual or auto
#7 hungdynasty
hungdynasty
  • 175 posts
Posted 03 December 2016 - 05:37 PM
It's manual, with mpi block, ECU101351
#8 Skipp
Skipp
  • 20 posts
Posted 04 December 2016 - 06:32 PM
OK mate I take it yours does run ok
