Gt175 Turbo
21 replies to this topic
#1 MINI-TURBO
MINI-TURBO
  • 230 posts
Posted 08 December 2016 - 12:07 AM
Hi all I've been given a gt1752 turbo for my mini from a saab but i think its from a new saab as its slightly different to the old one and the flange to bolt to the manifold is smaller. is it possible to get a conversion plate to put between the two or is it not worth the hassle and just selling it and getting another turbo.
one more question... if i was to get another turbo what would people recommend that i can bolt onto my metro turbo manifold?
Engine spec is:
metro turbo cylinder head
head face skimmed
ported and polished throughout
bigger maestro turbo valves fitted
new valve guides
double valve springs
1:5 roller rockers
arp head bolt kit
titanium push rods
new cam followers
kent md286 cam
metro turbo crankshaft
block rebored +20 thou
block face skimmed
med 4 bolt centre main strap
1275 A+ con rods end to end balanced
omega forged 18cc dished pistons
lightweight forged piston rings from MED
arp rod bolts
twin chain vernier timing gear
MED ultralight flywheel and backplate
MED turbo clutch
MED grey clutch cover
MED competition drive straps
MED en16t drive strap bolts
jack knight sc dog box
mini spares x pin diff
#2 mini13
mini13
  • 3,811 posts
Posted 08 December 2016 - 09:17 AM
1752 is a great turbo,
I have seen a few solutions, slotting the mounting holes on the turbo is a popular one,
do check the shaft for play though and also oil in the housings, the 17is a bit more fragile than the t3 as everythings a bit smaller, but rebuild kits are available.
#3 MINI-TURBO
MINI-TURBO
  • 230 posts
Posted 08 December 2016 - 11:22 AM
thanks mate, the turbo i have been given is brand new so hasn't got any play in shaft, ill get a picture of the size comparison to the manifold as I'm not sure if slotting the holes would be a good idea
#4 Midas Mk1
Midas Mk1
  • 5,853 posts
  • Local Club: S.U.N.M.C
Posted 08 December 2016 - 11:27 AM
286? Surely that's gonna be too wild for a turbo build, most people on turbominis run na mg, phase 2 , sw5 or 266?
Nice spec though! :thumbsup:
#5 MINI-TURBO
MINI-TURBO
  • 230 posts
Posted 08 December 2016 - 01:15 PM
I'm still unsure on them cam, its just what cam it a job lot of parts i got a while ago, so still in two minds to change it. glad you like the spec though its taken a while to get everything haha. they always cost more than you first think
#6 MINI-TURBO
MINI-TURBO
  • 230 posts
Posted 08 December 2016 - 01:22 PM
so this is the problem I'm dealing with, would slotting the holes be bit extreme as it is quite a difference between the two?
15310691_10153922230987676_979314035_n_z
15435753_10153922226887676_228341461_n_z
15328398_10153922224507676_1374224963_n_
#7 MINI-TURBO
MINI-TURBO
  • 230 posts
Posted 08 December 2016 - 01:25 PM
and i think i will need to modify the hole on the exhaust housing to be a bit bigger to improve flow as its small then the manifold.
#8 mini13
mini13
  • 3,811 posts
Posted 08 December 2016 - 01:49 PM
here you go, I have seen some washer things to spread the load as per the last pic,
also a 286 will be crap, swap it for an SW5, MG metro NA (kent 500),  266 or Kent 274i
#9 MINI-TURBO
MINI-TURBO
  • 230 posts
Posted 08 December 2016 - 01:58 PM
ah cool thanks for that! do you know anywhere i can get them or where i can get some made.
ok ill sell the cam and get another. if anyone know someone selling a suitable cam please point me in there direction or ill just get a new one.
thanks again for your help!
#10 mini13
mini13
  • 3,811 posts
Posted 08 December 2016 - 02:00 PM
they were just a bit of bar drilled and hacksawed to fit.
#11 MINI-TURBO
MINI-TURBO
  • 230 posts
Posted 08 December 2016 - 03:26 PM
oh ok nothing to fancy then haha
#12 mini13
mini13
  • 3,811 posts
Posted 08 December 2016 - 03:40 PM
Nope,
oh yeah, I also forgot, yep square out the inlet of the turbo a bit, also it might be worth grinding the fins back in the manifold too...
#13 Turbo Phil
Turbo Phil
  • 2,427 posts
Posted 08 December 2016 - 07:07 PM
Nice picture of my driveway there. Ha ha
Phil.
#14 mini13
mini13
  • 3,811 posts
Posted 08 December 2016 - 07:33 PM
Lol, using a lot of your pics today!
#15 MINI-TURBO
MINI-TURBO
  • 230 posts
Posted 08 December 2016 - 08:07 PM
Nope,
ok cool, thanks i was thinking of doing this to the fins to make the flow a bit more even
