Oh Bugger!
16 replies to this topic
#1 paulrockliffe
paulrockliffe
  • 1,763 posts
Posted 09 December 2016 - 10:37 PM
Trying to swap a Cooper S disc brake over, buggered it up at the first step.  Swapping them over because one of the studs has done it's splines, so I was able to put the stud in backwards, which stopped the disc spinning when undoing the big nut on the end.
Except the nut wouldn't budge and the lower caliper mount snapped off instead.  So new caliper needed.
Anyway, that nut is damn tight!  It's drivers side and I checked the Haynes manual, it doesn't say the thread is reversed or anything, so I was trying to undo it the normal way.  Any tips for getting it off?  I used a 2 foot bar that has never been defeated before.
#2 wile e coyote
wile e coyote
  • 1,230 posts
Posted 09 December 2016 - 10:59 PM
Cotter pin out?..... only joking...
The front hub nuts  are conventional - anti clock undo... no substitute for leverage - a bigger breaker bar needed it seems...done up to 180'ish so pretty tight .....
#3 paulrockliffe
paulrockliffe
  • 1,763 posts
Posted 09 December 2016 - 11:06 PM
I'd have snapped the cotter pin if it was still in!
I'm tempted to just drill the thinner bits and smash it off.  I don't have a longer bar, so would need to find time to get hold of one.
So annoyed about the caliper!
#4 Cooperman
  • 23,513 posts
Posted 09 December 2016 - 11:24 PM
Put 2 of the old studs back in and put a long bar between them to resist rotation.
Then with a long bar on the socket use a big club-hammer to free the nut. It usually works.
#5 panky
panky
  • 1,837 posts
Try drilling a hole in the nut and careful use of a chisel to split it, you might get away without damaging anything else, Either that or a length of tube on your cracker bar.
#6 cookie4343
cookie4343
    **Caution: Do Not Feed Alcohol**
  • 2,257 posts
  • Local Club: CV1 Mini's
Posted 09 December 2016 - 11:35 PM
Remove centre cap from wheel and cotter pin from the hub nut, with the wheel still on and mini on the ground get your breaker bar on it and crack the hub nut.
Then just jack up after and remove wheel.
#7 Cooperman
  • 23,513 posts
Posted 10 December 2016 - 12:16 AM
I thought he had removed all the studs.
#8 Magneto
Magneto
  • 891 posts
  • Local Club: KC MINI Club
Posted 10 December 2016 - 12:23 AM
No one over there seems to have access to an impact wrench?
If you hadn't buggered the caliper, you could have driven it down to the closest shop and had them bang them loose for you........
#9 paulrockliffe
paulrockliffe
  • 1,763 posts
Posted 10 December 2016 - 08:01 AM
I've still got 3 studs on, just the one had come out because it spun when I undid the wheel.  Sounds like I need a longer bar or to break the nut then.
I don't have an impact wrench, but next time I will take it to the garage!
#10 Ethel
  • 26,580 posts
Posted 10 December 2016 - 11:59 AM
The less springy the bar is the better. There are plenty of cordless impact drivers about now, not forgetting the good ole hit it wiv a big hammer type, so you may be able to scrounge one or persuade a spanner monkey to stop by on his way home for a few beer tokens.
#11 dyshipfakta
dyshipfakta
  • 1,696 posts
Posted 10 December 2016 - 12:54 PM
You can get a pretty decent plug in electric one from machine mart for about 50 quid. Will come in handy for other things.
#12 paulrockliffe
paulrockliffe
  • 1,763 posts
Posted 10 December 2016 - 07:58 PM
I gave it another go tonight; jammed the brake on, put my 2' bar on then went to find something suitable to extend it with.  The only thing I could find was an 9' washing line pole, so gave that a go.
The brakes were full on, but rather than moving the nut the caliper moved on it's one remaining fixing instead.  And because the fixing was nipped up tight the aluminium casting cracked on that one too and the caliper fell off!
So I drilled one of the recesses, smashed a chisel into it, then used the chisel to tap the nut round and loose.  The nut and caliper are off now!  I guessed the inevitable outcome, so ordered a new nut this morning, but need to get another caliper sorted.  Progress I suppose!
#13 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 10 December 2016 - 09:42 PM
Which disc size?
Link to the disc brake page on minispares.com
http://www.minispare...ers.aspx?040101
Edited by cal844, 10 December 2016 - 09:45 PM.
#14 paulrockliffe
paulrockliffe
  • 1,763 posts
Posted 10 December 2016 - 10:00 PM
7.5" Cooper S brakes.
Does anyone know if the Minispares calipers are as good as the 'Genuine' AP ones that are twice the price?
#15 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 10 December 2016 - 10:02 PM
They are copies and are very good according to posts on here
