Drive Shaft Nut Removal
9 replies to this topic
#1 James_eaton_thewholething
  • 1,063 posts
Posted 10 December 2016 - 09:55 PM
So as title states, I need to remove the nut off the end of the drive shafts.
Now I know this isn't difficult while the subframe is in the car and the drive shafts are attached to the engine.
I need some ideas of how to strip the rice shafts from the hubs now that the subframe isn't on the car
#2 paulrockliffe
paulrockliffe
  • 1,763 posts
Posted 10 December 2016 - 10:05 PM
Could you pin the subframe to the ground with a scaffold board and another car?  If you can stop the subframe lifting, you can then lock the axle using a bar and two of the wheel studs, then unscrew the nut.
Mind you if it's anything like mine - see thread above this one - you might as well save yourself the bother and break the nut.
#3 neal
neal
  • 318 posts
Posted 10 December 2016 - 10:45 PM
This is exactly how I did it and put a foot on the subframe, no problems and easy as peas.
#4 Anthony30
Anthony30
  • 1,467 posts
  • Local Club: N/A
Posted 11 December 2016 - 01:19 AM
air tools are your friends. :shades:  ;D
#5 Will16
Will16
    Wants a custom member title
  • 1,090 posts
Posted 11 December 2016 - 08:53 AM
Just use an impact gun, electric or air will shift it in seconds :thumbsup:
#6 James_eaton_thewholething
  • 1,063 posts
Posted 13 December 2016 - 12:39 PM
I can certainly do that. Now just to find where I have put my impact gun
#7 Magneto
Magneto
  • 889 posts
  • Local Club: KC MINI Club
Posted 14 December 2016 - 04:39 PM
I've never seen an electric impact that will get lug nuts off let alone the axle nut - and I have one! Some air powered impacts don't do what they advertise either - I bought one that claimed it had 400ft lbs of torque -wouldn't take off lug nuts that were torqued to 100 ft lbs, so I bought one rated at 800 ft lbs, that one does the job every time!
#8 Will16
Will16
  • 1,090 posts
Posted 14 December 2016 - 05:21 PM
Depends on what you've got to be honest! My dewalt 110v buzzed them straight off, with just the subby sat on the floor, no engine, etc. Even my work issue 18v battery makita one worked with some back / forth action ;-)
#9 Spider
  • 15,136 posts
Posted 14 December 2016 - 06:58 PM
The fit of the sockets, extension bars (if used) and the socket to the Nuts / Bolts has a lot to do with how effective Impact tools are, especially electric ones I've found. Sometimes if the tool accessories are held 'loaded' they will get the more stubborn ones undone.
#10 finch661
finch661
  • 2,339 posts
Posted 16 December 2016 - 01:29 PM
i bought this
https://www.amazon.c...-1&keywords=12v
have never had any issue with any nuts now :)
