Relay Pack Function And Starting Problems
Posted 15 December 2016 - 05:45 PM
Two months down the line, today it's done the same thing again. Engine will crank but got no ignition light or fuel pump. However I do have a spark.
I have read through Flying Scots threads about the spi system and my thoughts are that it's a faulty main relay pack. Is it possible to dissemble the relay pack and clean up contacts? I would appreciate it if anyone could let me know their experiences and could suggest anything to help.
Cheers Tyler
Posted 17 December 2016 - 12:51 AM
Yes you can carefully split the pack open with a sharp craft knife (later ones are heavily glued). That's how I took the pictures.
Test with a multimeter first before going to all the bother though. A meter set to ohms across the contacts will give a clue.
FS
Posted 21 July 2017 - 06:03 PM
Flying Scott could the alternator exciter wire also power up the ecu or relay pack?
Tyler
Posted 22 July 2017 - 07:13 PM
The charge warning light in the clocks is fed by the same 12v that feeds the relay pack and the ECU (all with a white wire). Same fuse. 12v is supplied from the ignition switch on a white wire to a fuse, and then from there it feeds the ECU, relay pack and the clocks.
Word of caution. There is a diode in the brown/ yellow wire preventing the alternator back feeding 12v and holding the ECU 'live'. Without the diode, the engine will miraculously keep running even after you have withdrawn the key from the ignition switch.
