Hi
I ended up speaking with my local a series engine chappy and over about 20 mins talking and coming to the conclusion the my 998 build will shift once put back in the car we ended up on the talk of carbs, I said I was sticking with my HIF38 which we both decided would provide a nice spread of torque and power across the full band where as the HIF44 would proberly give a but more in the top end but less pull low down.
Now this may sound excessive but I ended up thumbing through david vizards book last night and had a good look at flow rates and produced power using weber carbs on modified cooper 's' engines and they seemed to report good reponse.
Would a weber be a good way to go eventually rather that sticking with the HIF38?
Full build is
A+ 998 block bored to +80
Fully port and flowed 998 head with 1098 inlet/exhaust valves
Keith Calver ROT13 cam (kent 266/276 territory)
I will eventually have a lightened flywheel and to this point the bottom end is pretty much standard.
Many thanks to any thought given good or bad.
Nate
