Removing Under Bonnet Strengthening
20 replies to this topic
#1 Will16
Will16
    Wants a custom member title
  • 1,090 posts
Posted 27 December 2016 - 08:14 PM
I'm quite keen to remove the strengthening inder my bonnet, and make it single skin and a bit lighter. How are these stuck on? Welded? Bonded? And what's the best way to remove these?
I don't really want to affect the paint on 'outside' of the bonnet.
#2 bluemini1979
bluemini1979
  • 619 posts
  • Local Club: Colchester Mini Club
Posted 27 December 2016 - 08:39 PM
they are spot welded on
#3 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 27 December 2016 - 08:50 PM
I removed the bracing on steel bonnet for some clearance.
It is very very flimsy now. I wouldn't  dare use it
#4 sledgehammer
sledgehammer
  • 3,107 posts
Posted 27 December 2016 - 08:59 PM
If you consider doing this , it would be best to secure it in all 4 corners
possibly with a rubber foot on the inner wing about half way along the wing
in the middle of the scuttle & the centre of the slam panel
consider it a cover rather than a bonnet
as above a considerable amount of strength will be removed
you may have to put something in the middle to stop vibration
sadly not a lot of weight saved - but sometimes every little helps
Edited by sledgehammer, 27 December 2016 - 09:00 PM.
#5 camrocok
camrocok
  • 29 posts
Posted 27 December 2016 - 09:16 PM
If it wasn't needed the original designers would not have included it. The mini wasn't exactly over engineered.
#6 Will16
Will16
  • 1,090 posts
Posted 27 December 2016 - 09:28 PM
Hmm ok, I may try it on the spare bonnet before I commit to my good one! How did you go about removing it? And where was it welded?
It defiantly will be secured down well! Can't really do the inner wing or slam panel things either :o .
Not fussed about what the designers included to be honest
#7 neal
neal
  • 318 posts
Posted 27 December 2016 - 09:45 PM
It's spot welded in the corners on the bonnet return lip, look for small round indentations and use a spot weld drill bit as it's neater that way. If you use a drill bit you will probably skid off centre of the weld and end up drilling a bigger hole.
http://www.halfords....CFe8K0wod4BEH7Q
Or,
http://www.ebay.co.u...98615505&crdt=0
Both are slightly different in design but work well.
Edited by neal, 27 December 2016 - 09:49 PM.
#8 Ethel
  • 26,029 posts
Posted 27 December 2016 - 10:21 PM
If it's for weight saving you could put some holes in them with a hole saw. It won't save much but it could look good.
#9 1984mini25
1984mini25
  • 8,785 posts
Posted 27 December 2016 - 11:13 PM
If your really bothered about weight saving, just swap it for a single skin fiberglass one.
#10 Steve220
Steve220
  • 5,064 posts
  • Local Club: BMC
Posted 28 December 2016 - 06:13 AM
^ This. The standard one will 'balloon' without the brace bars underneath as you drive at speed. Chances it will rip off and either hot your windscreen or get torn off and hit a car behind you.
#11 Will16
Will16
  • 1,090 posts
Posted 28 December 2016 - 11:17 AM
But the paint would never match if I buy a fibreglass one... Hence why I was asking about making a steel single skin one
TMF member 'mad mk1' has done the same and his is a rather fast mini! 13 sec 1/4 mile ;-)
Edited by Will16, 28 December 2016 - 11:17 AM.
#12 tiger99
tiger99
  • 8,584 posts
Posted 28 December 2016 - 03:22 PM
The amount of weight saving is so small that the idea of removing the stiffeners, with all the problems it entails, is just ridiculous.
As as for paint not matching on a glassfibre bonnet, that too is ridiculous if it is done properly. What WILL stand out like a sore thumb is the inevitable buckled, crumpled and rippled skin if you proceed with your plan.
I strongly recommend calculating how much performance increase you will actually get, and balance that against the problems.
Personally, if I was worried about weight saving to that extent, I would fit carbon fibre bonnet and boot lid, in their natural colour, so no need to worry about paint match. Or I would go on a diet. Most normal people can afford to lose more weight than a pair of bonnet stiffners.
#13 Will16
Will16
  • 1,090 posts
Posted 28 December 2016 - 07:17 PM
"There's no such thing as insignificant weight saving"
You haven't seen my paint :lol: I want to keep the original bonnet as I've already got a white fg front. I'm looking at parts, that I've already got, and what could be done to lighten them..
As for a diet, don't think I could loose much weight tbf!
#14 acrowot
acrowot
  • 278 posts
  • Local Club: manchester minis
Posted 30 December 2016 - 04:59 PM
I run just a bonnet skin on my race car not lost it yet its got a pair of bonnet pins and 2 plates riveted to scuttle panel every little helps
#15 62S
62S
  • 1,243 posts
  • Local Club: You must be joking!
Posted 30 December 2016 - 09:24 PM
Some of the early 997 Cooper works prepared rally cars had most of the bracing removed only keeping the area where the hinges are mounted.
