Running In
17 replies to this topic
#16 carbon
carbon
  • 2,590 posts
Posted 01 January 2017 - 05:44 PM
Turning my attention to getting the timing advance sorted as I think this could be part of the reason for poor running as well as carb tuning.
Going to invest in timing gun....yikes!
If it's a pre-80 A-Series then chances are there will be a 'window' on the clutch cover that allows you to see the timing marks on the flywheel. With an 'old school' points type distributor this can be used to set up the ignition timing more accurately than a strobe.
Can you give more details for the engine spec (cam, compression ratio, head, exhaust etc) and the type of SU carb you're using? Chances are someone on the forum may already be running fairly similar, and this should get you in the right ball park.
#17 Shaggy33
Shaggy33
  • 311 posts
Posted 01 January 2017 - 06:31 PM
Good idea! Here you go....
1275 spi donor bored out to 1293 with fresh head. Kent 266 cam, 9.4.1 compression and fdr3.1
H&H recon dizzy and new coil
#18 carbon
carbon
  • 2,590 posts
Posted 02 January 2017 - 11:44 AM
May be worth starting a new thread. I'm also running 1293 with MD266 about 9.8 CR and 3.1FD. Using twin HS2s, RC40 twin box, and points distributor with vac advance.
