Parts Needed, Where From?
7 replies to this topic
#1 redhouse53
redhouse53
  • 111 posts
Posted 30 December 2016 - 10:53 AM
Hi, I'm after new heater hose clips and a new plastic piece for behind the grill, does anyone do them? Parts no.6 and 10 on here
thanks
#2 RedRuby
RedRuby
  • 1,201 posts
  • Local Club: No
Posted 30 December 2016 - 11:34 AM
Both the parts you need are available from Somerford mini, the support strap is in stainless steel, the air scope is not cheap mind at around £40-50. You may be able to get the air scope from someone on here if you put a post in the wanted section a good source is usually minijosh.
#3 minivanman8
minivanman8
    Previously known as minimadandy.
  • 426 posts
Somerford list this:
http://www.somerford...oducts_id=15255
As a new version of #10
#4 minivanman8
minivanman8
  • 426 posts
Posted 30 December 2016 - 11:35 AM
And show both vents as sold out on their website.
#5 redhouse53
redhouse53
  • 111 posts
Posted 31 December 2016 - 04:45 PM
Brilliant, thanks. I'll get the clips ordered, I was hoping someone would do a stainless version. I can probably live with the vent scoop thingy I've got.
#6 grck1
grck1
  • 198 posts
Posted 31 December 2016 - 06:10 PM
Should be able pick up a scoop at one off the shows in the autojumbles for not many pennies, if ya can wait till they start, minifair at Bingley Hall is at end of January.
#7 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 31 December 2016 - 06:18 PM
Best to check the flitch panels on both sides of the car for corrosion first(if it needs welded you'll need to remove the fresh air intake to weld it up
#8 morley
morley
  • 903 posts
Posted 31 December 2016 - 09:37 PM
I've got no.6 if you don't mind it not being new
