Brake Pipe/valve Location Problem
No replies to this topic
#1 msgorbra
msgorbra
  • 19 posts
Posted 02 January 2017 - 09:42 AM
Hi,
I´m about to fit all brakepipes and valve etc to my LHD Clubman - 71.
I have a couple of ?
  1. Where goes the pipes In the front from the left brakehose to number 2 on the picture. Forward and in front and around of the engine held with clips to the frame??
  2. Where is Number 1 on the picture located and what is the meaning of that one?
  3. Is there always a brake pressure regulator fitted in the rear from rear brakes and before the one-pipe going forward?
  4. Number 2 on the picture. On this one there is only one hole on the pressure housing but two pipes should connect, how does this work??
Grateful for replies
Best regards
Goran
