Rear Fog Light Fuse Location
11 replies to this topic
#1 andyt
andyt
  • 375 posts
  • Local Club: cooper register
Posted 08 January 2017 - 09:34 PM
I have an intermittent fault where I lose power to the rear foglight switch, where is the fuse that goes to the switch, the car is a 1992 mayfair.
Andy.
#2 cal844
cal844
  • 9,660 posts
  • Local Club: TFMOC
Posted 08 January 2017 - 11:00 PM
That circuit is unfused, test the switch for power in and out of switch, then check for power at the light end... Then check the fusebox and all wiring connections for corrosion(best to remove from the car, mark up all wiring and clean as necessary :)
Edited by cal844, 08 January 2017 - 11:03 PM.
#3 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 08 January 2017 - 11:01 PM
Beat me to a answer, as above check the feed into and out of the switch, replace as required if there is 12v into the switch, but none out
#4 cal844
cal844
  • 9,660 posts
  • Local Club: TFMOC
Posted 08 January 2017 - 11:03 PM
Just a little too slow tonight Dave ;)
#5 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 08 January 2017 - 11:13 PM
HaHa yes mate just come on ;D
#6 cal844
cal844
  • 9,660 posts
  • Local Club: TFMOC
Posted 08 January 2017 - 11:16 PM
Will let you off, you busy man :D
#7 andyt
andyt
  • 375 posts
Posted 10 January 2017 - 09:22 PM
Thanks for the replies, why in the Haynes manual does it show an inline fuse?
#8 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,043 posts
Posted 10 January 2017 - 09:28 PM
On my '82 and '85 they both have inline fuses, (one for the interior light and one for the fog I think) the fuse should be under the scuttle between bulkhead panel grommet and the grommet that takes the wires to the back of the car.
you can see them in my pic here above the carb.
Edited by alex-95, 10 January 2017 - 09:31 PM.
#9 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 10 January 2017 - 09:36 PM
Just had a quick look and the later cars did have a 10amp fuse for the rear fog light and they are indeed below the wiper panel as per Alexs picture, you wiring manual will show the colours im/out the fuse, i don't have access to a wiring diagram at the moment.
#10 alex-95
alex-95
  • 6,043 posts
Posted 10 January 2017 - 09:50 PM
I think it could be blue yellow (maybe blue orange)
#11 andyt
andyt
  • 375 posts
Posted 11 January 2017 - 08:35 PM
Thanks very much i'll  look tomorrow.
#12 hugosnel
hugosnel
  • 21 posts
Posted 30 July 2023 - 09:28 AM
I am going crazy!
10 amp fuse keeps popping out, and I cannot find the origin..
Please help
Edited by hugosnel, 30 July 2023 - 09:29 AM.
