Is There A Voltage Regulator/stabilizer For The Gauges On A Mpi ?
15 replies to this topic
#1 eric.sen
eric.sen
  • 113 posts
Posted 09 January 2017 - 12:27 PM
Hello,
I'm not sure if there is a voltage stabilizer on the back of the fuel and temperature gauges on MPI.
On other model I know that there is one (LUCAS parts BR1303/20 ) minispares number : BMK1539A
But I saw the back of Mini MPI gauges on forums and Ebay, and on MPI this part is not present.
Its for my MPI Cooper Sport year 2000.
(because temperature and fuel gauges are always low ....
And my Skykes ACR4 saw nothing wrong.
Thanks.
Eric from France.
#2 Ethel
  • 26,022 posts
Posted 09 January 2017 - 02:54 PM
I don't think the gauges have anything to do with the engine management. The Nippon instrument pod has the voltage stabiliser built inside.
#3 cian
cian
  • 869 posts
  • Local Club: Minis In Northern Ireland
Posted 09 January 2017 - 03:05 PM
Yes there's a voltage reducer I believe! Goes from 12v to 6 if I recall
I have 2 instock I think
Edited by cian, 09 January 2017 - 03:05 PM.
#4 Steve220
Steve220
  • 5,062 posts
  • Local Club: BMC
Posted 09 January 2017 - 03:26 PM
There's one inside the instrument pack
#5 FlyingScot
FlyingScot
  • 2,664 posts
Posted 09 January 2017 - 03:37 PM
Pretty sure the signal for the temp is PWM from the MEMS ECU, the sensor is read by the ECU and the gauge signal comes from the ECU. Is your ACR coolant temp consistent with the gauge ?
FS
#6 eric.sen
eric.sen
  • 113 posts
Posted 09 January 2017 - 04:47 PM
The reading of the data streaming of the ACR4 is correct.
But the water coolant temp gauge always goes at 1/3 ;   never on the line on the half of the gauge.
And when I refill the fuel tank to the full, the fuel gauge go to 3/4....
It's boring !!! because after less than 100 kilometers ; it goes to empty !!!
PS: I had already changed the petrol tank sender unit Inside the tank.
Steve220 and CIAN are you sure there is a voltage stabilizer ?
Where is it located, have you the reference of the part ?
Many Thanks for your help.
#7 cian
cian
  • 869 posts
Posted 09 January 2017 - 04:59 PM
I made a new dash with new gauges and that exact same thing happened to my fuel and temp gauges, researched the Haynes and found it needed a reducer, wired an aftermarket voltage reducer and it worked
#8 Steve220
Steve220
  • 5,062 posts
  • Local Club: BMC
Posted 10 January 2017 - 02:40 AM
It's integral. Without having a set of instruments in front of me, I couldn't tell.
#9 David106
David106
  • 11 posts
Posted 10 January 2017 - 08:03 AM
Both temperature and fuel gauges are a single part actually and I'd say the voltage regulator is also "embedded" in that single part. At least, I couldn't find any separate part that could be the voltage regulator. Cheers,
#10 Steve220
Steve220
  • 5,062 posts
  • Local Club: BMC
Posted 10 January 2017 - 08:39 AM
That's pretty much how I guessed it. It's the same in rover 200 R8 series.
#11 Fast Ivan
Fast Ivan
  • 2,910 posts
Posted 10 January 2017 - 08:45 AM
the voltage regulator, as suggested above, is integral to the nippon gauges and is not replaceable
#12 eric.sen
eric.sen
  • 113 posts
Posted 10 January 2017 - 09:43 AM
Sad news that it is integrated to the Nippon gauges and not remplaceable.
I fount his topic a simple modification to do but is it Worth ,
I don't know...
http://www.theminifo...howtopic=146533
This topic was made by Guess-Works
#13 David106
David106
  • 11 posts
Posted 10 January 2017 - 07:12 PM
Great, that identifies the three terminals of the embedded voltage regulator. There should be 12v between two of the terminals and ?v between other two of them, right? Would it be possible to check if it is working well by measuring those voltage levels? Cheers,
#14 g0myw
g0myw
  • Just Joined
  • 108 posts
Posted 24 June 2019 - 08:37 AM
great guide, and looks like just what I need to do ..
Any one got any tips having done this.?
#15 g0myw
g0myw
  • Just Joined
  • 108 posts
Posted 27 September 2019 - 05:17 PM
This week-ends job for me was to sort out the Voltage Regulator in the MPI
Dash is now out
I've got the part(s)
BUT [there's always a but]
the Thread with the great photos has been 'screwd' by photobucket..!!
does any one have a usable set of these photos to work from.
I'll even do some new ones while I do the job if it helps... :D
[p.s. I knew I should have printed them out when I first saw them... doh..]
