Tuning Advise On Airfilters
8 replies to this topic
#1 dsgoody
dsgoody
  • 519 posts
  • Local Club: Gert Lush Minis
Posted 22 January 2017 - 11:21 AM
Morning all,
My engine spec is as follows;
Overbored to +20 (1293) using 21253 pistons
MG Metro Large Valve Head
Mini Spares Evolution001 Cam
HIF44 on a Mini Spares Manifold
Drilled standard airbox with a K&N element
LCB with a twin box RC40
Electronic Distributer re-curved by H&H Ignition to ACDodd specs
I'm looking for slightly better performance; would a K&N cone and a stub stack do that?
I'm not sure what the current power is as it was never fully tested when run in.
Thanks,
Dave
Edited by dsgoody, 22 January 2017 - 11:44 AM.
#2 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 22 January 2017 - 11:35 AM
not really and when u say better performance what do you need
#3 dsgoody
dsgoody
  • 519 posts
Posted 22 January 2017 - 11:47 AM
Just looking at optimizing what I have really; didn't know if the standard airbox would be too restrictive. It was tuned last year and I will have it done again this year now it's fully run in.
#4 Midas Mk1
Midas Mk1
  • 5,823 posts
  • Local Club: S.U.N.M.C
Posted 22 January 2017 - 12:09 PM
Itg med kit, made a right good difference compared to the k&n before. SC use these with their in ecru in kits too.
#5 nicklouse
  • 18,998 posts
Posted 22 January 2017 - 12:22 PM
Clean and re-oil your current KN.
#6 Dusky
Dusky
  • 5,322 posts
Posted 22 January 2017 - 01:12 PM
Drilled standard airbox flows enough for that cam and head. Polishing and opening up the elbow did improve mine a bit
#7 Northernpower
Northernpower
    Mr. 7-Port
  • 2,414 posts
  • Name: Graham
Posted 22 January 2017 - 02:20 PM
Keith Calver wrote a very good article on this. http://www.calverst....air-filtration/
#8 Turbo Phil
Turbo Phil
  • 2,427 posts
Posted 22 January 2017 - 05:34 PM
Some basic head work to make use of that bigger inlet valve would be the next logical step.
Phil.
#9 ACDodd
ACDodd
  • Mini Docs
  • 2,832 posts
Posted 23 January 2017 - 01:13 PM
As Phil said modified head, and then ad a lightened and balanced flywheel assembly. Then have the engine properly dialled in on a rolling road.
Ac
