Correct Spark Plugs When Using Coil Pack
5 replies to this topic
#1 mini-geek
mini-geek
  • 1,169 posts
Posted 26 January 2017 - 11:30 AM
Something in my head is telling me that you need certain spark plugs when running a coil pack (car runs on specialist components ecu) so not the standard coil and dizzy..
Can anyone point me in the right direction?
#2 mini13
mini13
  • 3,811 posts
Posted 26 January 2017 - 11:38 AM
anything resistor'd ( whioch they pretty much all are these days) so a standard SPI/MPI plug will be fine, NGK BPR5E or BPR6E the 6 is colder
#3 mini-geek
mini-geek
  • 1,169 posts
Posted 26 January 2017 - 11:45 AM
When you say colder what does that mean?
#4 nicklouse
  • 18,682 posts
Posted 26 January 2017 - 11:49 AM
higher number so it runs colder so can work I higher temps in performance engines.
but just use what you would normally.
#5 Midas Mk1
Midas Mk1
  • 5,787 posts
  • Local Club: S.U.N.M.C
Posted 26 January 2017 - 12:03 PM
Last few times my engines have been to the dyno i've been recommended BRE7E's over the 6's for running colder as above.
Noticed when the engines cold they seem to foul a little and sometimes misfire , but after warming up seem fine.
Edited by Midas Mk1, 26 January 2017 - 12:04 PM.
#6 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 26 January 2017 - 08:23 PM
7's seem a tad cold if you ask me on anything other than a balls out forced induction motor or Nitrous oxide injection. Most use the 6's even in forced indiction. If it's not turbo'd, I'd definitely use the 6's.
did the 6's show signs of overheating to justify the change to 7's?
